Data SheetAD9265TIMING SPECIFICATIONS Table 5. ParameterConditionsMinTypMaxUnit SYNC TIMING REQUIREMENTS tSSYNC SYNC to rising edge of CLK setup time 0.30 ns tHSYNC SYNC to rising edge of CLK hold time 0.40 ns SPI TIMING REQUIREMENTS tDS Setup time between the data and the rising edge of SCLK 2 ns tDH Hold time between the data and the rising edge of SCLK 2 ns tCLK Period of the SCLK 40 ns tS Setup time between CSB and SCLK 2 ns tH Hold time between CSB and SCLK 2 ns tHIGH SCLK pulse width high 10 ns tLOW SCLK pulse width low 10 ns tEN_SDIO Time required for the SDIO pin to switch from an input to an 10 ns output relative to the SCLK falling edge tDIS_SDIO Time required for the SDIO pin to switch from an output to an 10 ns input relative to the SCLK rising edge Timing DiagramsN – 1N + 4tAN + 5NN + 3VINN + 1N + 2tCHtCLtCLKCLK+CLK–tDCODCO/DCO+DCO–tSKEWLVDS (DDR) MODEtPDD0/1+ TO D14/D15+DExDOxDExDOxDExDOxDExDOxDExDOxD0/1– TO D14/D15–– 12– 12– 11– 11– 10– 10– 9– 9– 8– 8CMOS MODED0 TO D15Dx – 12Dx – 11Dx – 10Dx – 9Dx – 8NOTES 002 1. DEx DENOTES EVEN BIT. 2. DOx DENOTES ODD BIT. 08502- Figure 2. LVDS (DDR) and CMOS Output Mode Data Output Timing CLK+ttSSYNCHSYNCSYNC 104 08502- Figure 3. SYNC Input Timing Requirements Rev. C | Page 9 of 44 Document Outline Features Applications Product Highlights Functional Block Diagram Table of Contents Revision History General Description Specifications ADC DC Specifications ADC AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation ADC Architecture Analog Input Considerations Input Common Mode Dither Large Signal FFT Small Signal FFT Static Linearity Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Clock Duty Cycle Input Clock Divider Jitter Considerations Power Dissipation and Standby Mode Digital Outputs Digital Output Enable Function (OEB) Timing Data Clock Output (DCO) Built-In Self-Test (BIST) and Output Test Built-In Self-Test (BIST) Output Test Modes Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open Locations Default Values Logic Levels Transfer Register Map Memory Map Register Table Memory Map Register Descriptions Sync Control (Register 0x100) Applications Information Design Guidelines Power and Ground Recommendations LVDS Operation Exposed Paddle Thermal Heat Slug Recommendations VCM RBIAS Reference Decoupling SPI Port Outline Dimensions Ordering Guide
