Datasheet AD9231 (Analog Devices) - 11
Description12-Bit, 20 MSPS/40 MSPS/65 MSPS/80 MSPS, 1.8 V Dual Analog-to-Digital Converter
Pages / Page37 / 11 — AD9231. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. IN+. …
File Format / SizePDF / 970 Kb
AD9231. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. IN+. IN–B. IN–. RBI. SEN. CLK+. PIN 1. 48 PDWN. INDICATOR. CLK–. 47 OEB. SYNC
AD9231 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS IN+ IN–B IN– RBI SEN CLK+ PIN 1 48 PDWN INDICATOR CLK– 47 OEB SYNC
AD9231 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS B SE A A DD DD DD DD AS EF DD DD DD DD V V IN+ IN–B V V CM V V IN– IN+ V V A A V V A A RBI V SEN VR A A V V A A 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 CLK+ 1 PIN 1 48 PDWN INDICATOR CLK– 2 47 OEB SYNC 3 46 CSB NC 4 45 SCLK/DFS NC 5 44 SDIO/DCS NC 6 43 ORA NC 7 AD9231 42 D11A (MSB) (LSB) D0B 8 41 D10A TOP VIEW D1B 9 40 D9A (Not to Scale) DRVDD 10 39 D8A D2B 11 38 D7A D3B 12 37 DRVDD D4B 13 36 D6A D5B 14 35 D5A D6B 15 34 D4A D7B 16 33 D3A 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 B A A A A DD 1B RB NC NC NC DD NC 0 D8B D9B V 1 O V D1 D2 R D10B DCO DCO R ) D D ) D D SB
005
(L (MSB
08121-
NOTES 1. NC = NO CONNECT. 2. THE EXPOSED PADDLE MUST BE SOLDERED TO THE PCB GROUND TO ENSURE PROPER HEAT DISSIPATION, NOISE, AND MECHANICAL STRENGTH BENEFITS.
Figure 5. Pin Configuration
Table 8. Pin Function Description Pin No. Mnemonic Description
0 GND Exposed paddle is the only ground connection for the chip. Must be connected to PCB AGND. 1, 2 CLK+, CLK− Differential Encode Clock. PECL, LVDS, or 1.8 V CMOS inputs. 3 SYNC Digital Input. SYNC input to clock divider. 30 kΩ internal pull-down. 4, 5, 6, 7, 25, 26, 27, 29 NC Do Not Connect. 8 to 9, 11 to 18, 20, 21 D0B to D11B Channel B Digital Outputs. D11B = MSB. 10, 19, 28, 37 DRVDD Digital Output Driver Supply (1.8 V to 3.3 V). 22 ORB Channel B Out-of-Range Digital Output. 23 DCOB Channel B Data Clock Digital Output. 24 DCOA Channel A Data Clock Digital Output. 30 to 36, 38 to 42 D0A to D11A Channel A Digital Outputs. D11A = MSB. 43 ORA Channel A Out-of-Range Digital Output. 44 SDIO/DCS SPI Data Input/Output (SDIO). Bidirectional SPI Data I/O in SPI mode. 30 kΩ internal pull- down in SPI mode. Duty Cycle Stabilizer (DCS). Static enable input for duty cycle stabilizer in non-SPI mode. 30 kΩ internal pull-up in non-SPI (DCS) mode. 45 SCLK/DFS SPI Clock (SCLK) Input in SPI mode. 30 kΩ internal pul -down. Data Format Select (DFS). Static control of data output format in non-SPI mode. 30 kΩ internal pull-down. DFS high = twos complement output. DFS low = offset binary output. 46 CSB SPI Chip Select. Active low enable; 30 kΩ internal pull-up. 47 OEB Digital Input. Enable Channel A and Channel B digital outputs if low, tristate outputs if high. 30 kΩ internal pull-down. 48 PDWN Digital Input. 30 kΩ internal pull-down. PDWN high = power-down device. PDWN low = run device, normal operation. Rev. B | Page 10 of 36 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS AD9231-80 AD9231-65 AD9231-40 AD9231-20 EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations Single-Ended Input Configuration VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations CHANNEL/CHIP SYNCHRONIZATION POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS Digital Output Enable Function (OEB) TIMING Data Clock Output (DCO) BUILT-IN SELF-TEST (BIST) AND OUTPUT TEST BUILT-IN SELF-TEST (BIST) OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE OPEN LOCATIONS DEFAULT VALUES Logic Levels Transfer Register Map Channel-Specific Registers MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS Sync Control (Register 0x100) Bits[7:3]—Reserved Bit 2—Clock Divider Next Sync Only Bit 1—Clock Divider Sync Enable Bit 0—Master Sync Enable Bit 7—Enable OEB Pin 47 Bit 3—Enable GCLK Detect Bit 2—Run GCLK Bit 0—Disable SDIO Pull-Down APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations Exposed Paddle Thermal Heat Sink Recommendations VCM RBIAS Reference Decoupling SPI Port OUTLINE DIMENSIONS ORDERING GUIDE
