Datasheet AD7626 (Analog Devices) - 6
Description16-Bit, 10 MSPS, PulSAR Differential ADC
Pages / Page30 / 6 — Data Sheet. AD7626. Parameter. Test Conditions/Comments. Min. Typ. Max. …
RevisionD
Data Sheet. AD7626. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD7626 Parameter Test Conditions/Comments Min Typ Max Unit
TEMPERATURE RANGE Specified Performance TMIN to TMAX −40 +85 °C 1 Using an external reference. 2 The ANSI-644 LVDS I/O specification has a minimum output common mode (VOCM) of 1125 mV. 3 Power dissipation is for the AD7626 device only. In self clocked interface mode, 0.9 mW is dissipated in the 100 Ω terminator. In echoed clock interface mode, 1.8 mW is dissipated in two 100 Ω terminators. Rev. D | Page 5 of 29 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER INFORMATION TRANSFER FUNCTIONS ANALOG INPUTS TYPICAL CONNECTION DIAGRAM DRIVING THE AD7626 Differential Analog Input Source Single-Ended to Differential Driver Single-Ended or Fully Differential High Frequency Driver VOLTAGE REFERENCE OPTIONS Wake-Up Time from EN1 = 0, EN0 = 0 POWER SUPPLY Power-Up DIGITAL INTERFACE Conversion Control Echoed Clock Interface Mode Self Clocked Mode APPLICATIONS INFORMATION LAYOUT, DECOUPLING, AND GROUNDING Exposed Paddle VDD1 Supply Routing and Decoupling VIO Supply Decoupling Layout and Decoupling of Pin 25 to Pin 32 OUTLINE DIMENSIONS ORDERING GUIDE
