Datasheet AD9267 (Analog Devices) - 7
Description10 MHz Bandwidth, 640 MSPS Dual Continuous Time Sigma-Delta Modulator
Pages / Page25 / 7 — AD9267. SWITCHING SPECIFICATIONS. Table 4. Parameter1 C. …
File Format / SizePDF / 562 Kb
AD9267. SWITCHING SPECIFICATIONS. Table 4. Parameter1 C. onditions/Comments. Temp. Min. Typ. Max. Unit. Timing Diagram. CLK±. tDCO. DCO±. SKEW
AD9267 SWITCHING SPECIFICATIONS Table 4 Parameter1 C onditions/Comments Temp Min Typ Max Unit Timing Diagram CLK± tDCO DCO± SKEW
link to page 20 link to page 20 link to page 7 link to page 7 link to page 7
AVDD = 1.8 V, DRVDD = 1.8 V, unless otherwise noted.
Table 4. Parameter1 C onditions/Comments Temp Min Typ Max Unit
CLOCK INPUT PARAMETERS Using clock multiplier Input CLK Rate Full 30 160 MSPS CLK± Period Full 6.25 33.3 ns CLK± Duty Cycle Full 40 50 60 % CLOCK INPUT PARAMETERS Direct clocking Conversion Rate Full 608 640 672 MSPS CLK± Period Full 1.48 1.5625 1.72 ns CLK± Duty Cycle Full 40 50 60 % DATA OUTPUT PARAMETERS Data Propagation Delay (tPD)2 Full 160 510 840 ps DCO± Propagation Delay (tDCO) Full -60 268 570 ps DCO± to Data Skew (tSKEW) Full 180 200 280 Ps Aperture Uncertainty (Jitter, tJ) Full 1 ps rms WAKE-UP TIME Power-Down Power 25°C 3 Μs Standby Power 25°C 9 μs Sleep Power 25°C 15 μs OUT-OF-RANGE RECOVERY TIME 25°C 100 ns SERIAL PORT INTERFACE3 SCLK Period (tSCLK) Full 40 ns SCLK Pulse Width High Time (tSHIGH) Full 16 ns SCLK Pulse Width Low Time (tSLOW) Full 16 ns SDIO to SCLK Set-Up Time (tSDS) Full 5 ns SDIO to SCLK Hold Time (tSDH) Full 2 ns CSB to SCLK Set-Up Time (tSS) Full 5 ns CSB to SCLK Hold Time (tSH) Full 2 ns 1 See the AN-835 Application Note, Understanding High Speed ADC Testing and Evaluation, for a complete set of definitions. 2 Output propagation delay is measured from CLK± 50% transition to data D0±x to D3±x 50% transition, with 5 pF load. 3 See Figure 42 and the Serial Port Interface (SPI) section.
Timing Diagram CLK± tDCO DCO± t t PD SKEW
7 05 3-
D0±x TO D3±x
77 07 Figure 2. Timing Diagram Rev. 0 | Page 6 of 24 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Direct Clocking Internal PLL Clock Distribution External PLL Control PLL Autoband Select Power Dissipation and Standby Mode Digital Outputs Digital Output Format Overrange (OR) Condition Timing Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Applications Information Filtering Requirement Memory Map Memory Map Definitions Outline Dimensions Ordering Guide
