Datasheet AD7983 (Analog Devices) - 7
Description16-Bit, 1.33 MSPS PulSAR ADC in MSOP/QFN
Pages / Page25 / 7 — AD7983. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter. Rating. …
File Format / SizePDF / 592 Kb
AD7983. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter. Rating. ESD CAUTION
AD7983 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating ESD CAUTION
link to page 15
AD7983 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5. Parameter Rating
Stresses above those listed under Absolute Maximum Ratings Analog Inputs may cause permanent damage to the device. This is a stress IN+,1 IN−1 to GND −0.3 V to VREF + 0.3 V or ±130 mA rating only; functional operation of the device at these or any Supply Voltage other conditions above those indicated in the operational REF, VIO to GND −0.3 V to +6 V section of this specification is not implied. Exposure to absolute VDD to GND −0.3 V to +3 V maximum rating conditions for extended periods may affect VDD to VIO +3 V to −6 V device reliability. Digital Inputs to GND −0.3 V to VIO + 0.3 V Digital Outputs to GND −0.3 V to VIO + 0.3 V
ESD CAUTION
Storage Temperature Range −65°C to +150°C Junction Temperature 150°C θJA Thermal Impedance 10-Lead MSOP 200°C/W 10-Lead QFN (LFCSP) 48.7°C/W θJC Thermal Impedance 10-Lead MSOP 44°C/W 10-Lead QFN (LFCSP) 2.96°C/W Lead Temperature Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C 1 See the Analog Inputs section. Rev. B | Page 6 of 24 Document Outline Features Applications Application Diagram General Description Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Transfer Functions Typical Connection Diagram Analog Inputs Driver Amplifier Choice Voltage Reference Input Power Supply Digital Interface CS MODE, 3-Wire Without Busy Indicator CS Mode, 3-Wire with Busy Indicator CS Mode, 4-Wire Without Busy Indicator CS Mode, 4-Wire with Busy Indicator Chain Mode Without Busy Indicator Chain Mode with Busy Indicator Application Hints Layout Evaluating the Performance of the AD7983 Outline Dimensions Ordering Guide
