Datasheet AD7951 (Analog Devices) - 2
Description14-Bit, 1 MSPS, Unipolar/Bipolar Programmable Input PulSAR® ADC
Pages / Page33 / 2 — AD7951* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionB
File Format / SizePDF / 773 Kb
AD7951* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD7951* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD7951 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD7951 Evaluation kit • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all AD7951 EngineerZone Discussions. • AN-931: Understanding PulSAR ADC Support Circuitry
Data Sheet SAMPLE AND BUY
• AD7951: 14-Bit, 1 MSPS, Unipolar/Bipolar Programmable Visit the product page to see pricing options. Input PulSAR ADC Data Sheet
User Guides TECHNICAL SUPPORT
• EVAL-AD76XXCBZ: Evaluation Board For AD761x,762x/ Submit a technical question or find your regional support AD763x AD764x/AD765x/AD766x/AD767x/AD795x number.
REFERENCE MATERIALS DOCUMENT FEEDBACK Technical Articles
Submit feedback for this data sheet. • MS-2210: Designing Power Supplies for High Speed ADC
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION OVERVIEW CONVERTER OPERATION MODES OF OPERATION Normal Mode Impulse Mode TRANSFER FUNCTIONS TYPICAL CONNECTION DIAGRAM ANALOG INPUTS Input Range Selection Input Structure VOLTAGE REFERENCE INPUT/OUTPUT Internal Reference (REF = 5 V) (PDREF = Low, PDBUF = Low) External 2.5 V Reference and Internal Buffer (REF = 5 V) (PDREF = High, PDBUF = Low) External 5 V Reference (PDREF = High, PDBUF = High) Reference Decoupling Temperature Sensor POWER SUPPLIES Core Supplies High Voltage Supplies Digital Output Supply Power Sequencing Power Dissipation vs. Throughput Power Down CONVERSION CONTROL INTERFACES DIGITAL INTERFACE RESET PARALLEL INTERFACE Master Parallel Interface Slave Parallel Interface 8-Bit Interface (Master or Slave) SERIAL INTERFACE Data Interface Serial Configuration Interface MASTER SERIAL INTERFACE Internal Clock (SER/PAR = High, EXT/INT = Low) Read During Convert (RDC = High) Read After Convert (RDC = Low, DIVSCLK[1:0] = [0 to 3]) SLAVE SERIAL INTERFACE External Clock (SER/PAR = High, EXT/INT = High) External Discontinuous Clock Data Read After Conversion Daisy-Chain Feature External Clock Data Read During Previous Conversion External Clock Data Read After/During Conversion HARDWARE CONFIGURATION SOFTWARE CONFIGURATION MICROPROCESSOR INTERFACING SPI Interface APPLICATION INFORMATION LAYOUT GUIDELINES OUTLINE DIMENSIONS ORDERING GUIDE
