AD9259* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017COMPARABLE PARTSTOOLS AND SIMULATIONS View a parametric search of comparable parts. • Visual Analog • AD9259 IBIS Models EVALUATION KITS • AD9259 Evaluation Board REFERENCE MATERIALSTechnical ArticlesDOCUMENTATION • Matching An ADC To A Transformer Application Notes • MS-2210: Designing Power Supplies for High Speed ADC • AN-1142: Techniques for High Speed ADC PCB Layout • AN-282: Fundamentals of Sampled Data Systems DESIGN RESOURCES • AN-345: Grounding for Low-and-High-Frequency Circuits • AD9259 Material Declaration • AN-501: Aperture Uncertainty and ADC System • PCN-PDN Information Performance • Quality And Reliability • AN-715: A First Approach to IBIS Models: What They Are • Symbols and Footprints and How They Are Generated • AN-737: How ADIsimADC Models an ADC DISCUSSIONS • AN-741: Little Known Characteristics of Phase Noise View all AD9259 EngineerZone Discussions. • AN-742: Frequency Domain Response of Switched- Capacitor ADCs SAMPLE AND BUY • AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter Visit the product page to see pricing options. • AN-807: Multicarrier WCDMA Feasibility TECHNICAL SUPPORT • AN-808: Multicarrier CDMA2000 Feasibility Submit a technical question or find your regional support • AN-812: MicroController-Based Serial Port Interface (SPI) number. Boot Circuit • AN-827: A Resonant Approach to Interfacing Amplifiers to DOCUMENT FEEDBACK Switched-Capacitor ADCs • AN-835: Understanding High Speed ADC Testing and Submit feedback for this data sheet. Evaluation • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual • AN-935: Designing an ADC Transformer-Coupled Front End Data Sheet • AD9259: Quad, 14-Bit, 50 MSPS Serial LVDS 1.8 V ADC Data Sheet This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/ODM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Evaluation Board Power Supplies Input Signals Output Signals Default Operation and Jumper Selection Settings Alternative Analog Input Drive Configuration Outline Dimensions Ordering Guide
