Datasheet AD9228 (Analog Devices)
Description | Quad, 12-Bit, 40/65 MSPS Serial LVDS 1.8 V A/D Converter |
Pages / Page | 57 / 1 — Quad, 12-Bit, 40/65 MSPS. Serial LVDS 1.8 V A/D Converter. Data Sheet. … |
Revision | F |
File Format / Size | PDF / 1.6 Mb |
Quad, 12-Bit, 40/65 MSPS. Serial LVDS 1.8 V A/D Converter. Data Sheet. AD9228. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Quad, 12-Bit, 40/65 MSPS Serial LVDS 1.8 V A/D Converter Data Sheet AD9228 FEATURES FUNCTIONAL BLOCK DIAGRAM 4 ADCs integrated into 1 package AVDD PDWN DRVDD DRGND 119 mW ADC power per channel at 65 MSPS AD9228 SNR = 70 dB (to Nyquist) 12 VIN + A PIPELINE SERIAL D + A ENOB = 11.3 bits VIN – A ADC LVDS D – A SFDR = 82 dBc (to Nyquist) 12 VIN + B Excellent linearity PIPELINE SERIAL D + B VIN – B ADC LVDS D – B DNL = ±0.3 LSB (typical) 12 INL = ±0.4 LSB (typical) VIN + C PIPELINE SERIAL D + C VIN – C ADC LVDS D – C Serial LVDS (ANSI-644, default) 12 Low power, reduced signal option (similar to IEEE 1596.3) VIN + D SERIAL PIPELINE D + D Data and frame clock outputs VIN – D LVDS D – D ADC 315 MHz full-power analog bandwidth VREF FCO+ 2 V p-p input voltage range SENSE + – 0.5V FCO– DATA RATE 1.8 V supply operation REFT REF MULTIPLIER Serial port control REFB SELECT SERIAL PORT DCO+ INTERFACE DCO– Full-chip and individual-channel power-down modes Flexible bit orientation RBIAS AGND CSB SDIO/ODM SCLK/DTP CLK+ CLK–
1 -00
Built-in and custom digital test pattern generation
27 57 0
Programmable clock and data alignment
Figure 1.
Programmable output resolution Standby mode
capturing data on the output and a frame clock output (FCO) for signaling a new output byte are provided. Individual-
channel power-down is supported and typically consumes less
Medical imaging and nondestructive ultrasound
than 2 mW when all channels are disabled.
Portable ultrasound and digital beam-forming systems Quadrature radio receivers
The ADC contains several features designed to maximize
Diversity radio receivers
flexibility and minimize system cost, such as programmable
Tape drives
clock and data alignment and programmable digital test pattern
Optical networking
generation. The available digital test patterns include built-in
Test equipment
deterministic and pseudorandom patterns, along with custom user- defined test patterns entered via the serial port interface (SPI).
GENERAL DESCRIPTION
The AD9228 is available in an RoHS compliant, 48-lead LFCSP. It is The AD9228 is a quad, 12-bit, 40/65 MSPS analog-to-digital con- specified over the industrial temperature range of −40°C to +85°C. verter (ADC) with an on-chip sample-and-hold circuit designed for low cost, low power, small size, and ease of use. The product
PRODUCT HIGHLIGHTS
operates at a conversion rate of up to 65 MSPS and is optimized for 1. Small Footprint. Four ADCs are contained in a small, space- outstanding dynamic performance and low power in applications saving package. where a small package size is critical. 2. Low power of 119 mW/channel at 65 MSPS. The ADC requires a single 1.8 V power supply and LVPECL-/ 3. Ease of Use. A data clock output (DCO) is provided that CMOS-/LVDS-compatible sample rate clock for full performance operates at frequencies of up to 390 MHz and supports operation. No external reference or driver components are double data rate (DDR) operation. required for many applications. 4. User Flexibility. The SPI control offers a wide range of flexible features to meet specific system requirements. The ADC automatically multiplies the sample rate clock for the 5. Pin-Compatible Family. This includes the AD9287 (8-bit), appropriate LVDS serial data rate. A data clock output (DCO) for AD9219 (10-bit), and AD9259 (14-bit).
Rev. E Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2006–2011 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/ODM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Evaluation Board Power Supplies Input Signals Output Signals Default Operation and Jumper Selection Settings Alternative Analog Input Drive Configuration Outline Dimensions Ordering Guide
