Datasheet AD9228 (Analog Devices) - 2
DescriptionQuad, 12-Bit, 40/65 MSPS Serial LVDS 1.8 V A/D Converter
Pages / Page57 / 2 — AD9228* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
AD9228* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9228* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9228 IBIS Model
EVALUATION KITS
• AD9228 Evaluation Board
REFERENCE MATERIALS Technical Articles DOCUMENTATION
• Matching An ADC To A Transformer
Application Notes
• MS-2210: Designing Power Supplies for High Speed ADC • AN-1142: Techniques for High Speed ADC PCB Layout • AN-282: Fundamentals of Sampled Data Systems
DESIGN RESOURCES
• AN-345: Grounding for Low-and-High-Frequency Circuits • AD9228 Material Declaration • AN-501: Aperture Uncertainty and ADC System • PCN-PDN Information Performance • Quality And Reliability • AN-586: LVDS Outputs for High Speed A/D Converters • Symbols and Footprints • AN-715: A First Approach to IBIS Models: What They Are and How They Are Generated
DISCUSSIONS
• AN-737: How ADIsimADC Models an ADC View all AD9228 EngineerZone Discussions. • AN-741: Little Known Characteristics of Phase Noise • AN-756: Sampled Systems and the Effects of Clock Phase
SAMPLE AND BUY
Noise and Jitter Visit the product page to see pricing options. • AN-808: Multicarrier CDMA2000 Feasibility • AN-812: MicroController-Based Serial Port Interface (SPI)
TECHNICAL SUPPORT
Boot Circuit Submit a technical question or find your regional support • AN-827: A Resonant Approach to Interfacing Amplifiers to number. Switched-Capacitor ADCs • AN-835: Understanding High Speed ADC Testing and
DOCUMENT FEEDBACK
Evaluation • AN-905: Visual Analog Converter Evaluation Tool Version Submit feedback for this data sheet. 1.0 User Manual • AN-935: Designing an ADC Transformer-Coupled Front End
Data Sheet
• AD9228: Quad, 12-Bit, 40/65 MSPS Serial LVDS 1.8 V A/D Converter Data Sheet
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/ODM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Evaluation Board Power Supplies Input Signals Output Signals Default Operation and Jumper Selection Settings Alternative Analog Input Drive Configuration Outline Dimensions Ordering Guide
