Datasheet AD9219 (Analog Devices) - 4
Description | Quad, 10-Bit, 40/65 MSPS Serial LVDS 1.8 V A/D Converter |
Pages / Page | 57 / 4 — Data Sheet. AD9219. 4/06—Revision 0: Initial Version |
Revision | F |
File Format / Size | PDF / 1.6 Mb |
Data Sheet AD9219
Changes to RBIAS Pin Section .. 28 Jumper Selection Settings Section .. 37 Changes to Figure 67 .. 29 Changes to Alternative Analog Input Drive Configuration Changes to Hardware Interface Section ... 30 Section .. 38 Added Figure 68 .. 31 Changes to Figure 74 .. 40 Changes to Table 15 .. 31 Changes to Table 17 .. 48 Changes to Reading the Memory Map Table Section .. 32 Changes to Ordering Guide ... 52 Changes to Output Signals Section ... 36 Changes to Figure 71 .. 36
Changes to Default Operation and Rev. E | Page 3 of 56 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/ODM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Evaluation Board Power Supplies Input Signals Output Signals Default Operation and Jumper Selection Settings Alternative Analog Input Drive Configuration Outline Dimensions Ordering Guide
