Datasheet AD7690 (Analog Devices) - 2
Description18-Bit, 1.5 LSB INL, 400 kSPS PulSAR® Differential ADC in MSOP/QFN
Pages / Page25 / 2 — AD7690* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 684 Kb
AD7690* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
AD7690* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
View a parametric search of comparable parts.
Technical Articles
• MS-1779: Nine Often Overlooked ADC Specifications
EVALUATION KITS
• MS-2210: Designing Power Supplies for High Speed ADC • AD7690 Evaluation Kit
Tutorials
• Precision ADC PMOD Compatible Boards • MT-074: Differential Drivers for Precision ADCs
DOCUMENTATION DESIGN RESOURCES Application Notes
• AD7690 Material Declaration • AN-931: Understanding PulSAR ADC Support Circuitry • PCN-PDN Information • AN-932: Power Supply Sequencing • Quality And Reliability
Data Sheet
• Symbols and Footprints • AD7690: 18-Bit, 1.5 LSB INL, 400 kSPS PulSAR® Differential ADC in MSOP/QFN Data Sheet
DISCUSSIONS User Guides
View all AD7690 EngineerZone Discussions. • UG-340: Evaluation Board for the 10-Lead Family 14-/16-/ 18-Bit PulSAR ADCs
SAMPLE AND BUY
• UG-682: 6-Lead SOT-23 ADC Driver for the 8-/10-Lead Visit the product page to see pricing options. Family of 14-/16-/18-Bit PulSAR ADC Evaluation Boards
TECHNICAL SUPPORT SOFTWARE AND SYSTEMS REQUIREMENTS
Submit a technical question or find your regional support • AD7690 FMC-SDP Interposer & Evaluation Board / Xilinx number. KC705 Reference Design • BeMicro FPGA Project for AD7690 with Nios driver
DOCUMENT FEEDBACK TOOLS AND SIMULATIONS
Submit feedback for this data sheet. • AD7685 IBIS Models
Document Outline FEATURES APPLICATIONS APPLICATION EXAMPLE GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION Transfer Functions TYPICAL CONNECTION DIAGRAM ANALOG INPUTS DRIVER AMPLIFIER CHOICE SINGLE-TO-DIFFERENTIAL DRIVER VOLTAGE REFERENCE INPUT POWER SUPPLY SUPPLYING THE ADC FROM THE REFERENCE DIGITAL INTERFACE CS MODE, 3-WIRE WITHOUT BUSY INDICATOR CS MODE, 3-WIRE WITH BUSY INDICATOR CS MODE, 4-WIRE WITHOUT BUSY INDICATOR CS MODE, 4-WIRE WITH BUSY INDICATOR CHAIN MODE WITHOUT BUSY INDICATOR CHAIN MODE WITH BUSY INDICATOR APPLICATION HINTS LAYOUT EVALUATING THE AD7690 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
