Datasheet AD7327 (Analog Devices) - 2
Description500 kSPS, 8-Channel, Software Selectable True bipolar Input, 12-Bit Plus Sign A/D Converter
Pages / Page37 / 2 — AD7327* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 776 Kb
AD7327* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
AD7327* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
View a parametric search of comparable parts.
Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
EVALUATION KITS
• AD7327 Evaluation Board
DESIGN RESOURCES
• AD7327 Material Declaration
DOCUMENTATION
• PCN-PDN Information
Data Sheet
• Quality And Reliability • AD7327-DSCC: Military Data Sheet • Symbols and Footprints • AD7327-EP: Enhanced Product Data Sheet • AD7327: 500 kSPS, 8-Channel, Software-Selectable, True
DISCUSSIONS
Bipolar Input, 12-Bit Plus Sign ADC Data Sheet View all AD7327 EngineerZone Discussions.
User Guides
• UG-419: Evaluating the AD7327/AD7328
SAMPLE AND BUY
Visit the product page to see pricing options.
SOFTWARE AND SYSTEMS REQUIREMENTS
• AD7327 FMC-SDP Interposer & Evaluation Board / Xilinx
TECHNICAL SUPPORT
KC705 Reference Design Submit a technical question or find your regional support • AD7327/AD7328 Evaluation Software number. • BeMicro FPGA Project for AD7327 with Nios driver
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Output Coding Transfer Functions Analog Input Structure Track-and-Hold Section Typical Connection Diagram Analog Input Single-Ended Inputs True Differential Mode Pseudo Differential Inputs Driver Amplifier Choice Registers Addressing Registers Control Register Sequence Register Range Registers Sequencer Operation Reference VDRIVE Temperature Indicator Modes of Operation Normal Mode Full Shutdown Mode Autoshutdown Mode Autostandby Mode Power vs. Throughput Rate Serial Interface Microprocessor Interfacing AD7327 to ADSP-21xx AD7327 to ADSP-BF53x Application Hints Layout and Grounding Power Supply Configuration Outline Dimensions Ordering Guide
