Datasheet AD7324 (Analog Devices) - 2
DescriptionSoftware Selectable True Bipolar Input, 4-Channel, 12-Bit Plus Sign A/D Converter
Pages / Page37 / 2 — AD7324* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 746 Kb
AD7324* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD7324* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD7324 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD7324 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all AD7324 EngineerZone Discussions. • AD7324: 4-Channel, Software-Selectable, True Bipolar Input, 12-Bit Plus Sign ADC Data Sheet
SAMPLE AND BUY
Visit the product page to see pricing options.
SOFTWARE AND SYSTEMS REQUIREMENTS
• AD7324 Evaluation Software
TECHNICAL SUPPORT
Submit a technical question or find your regional support
REFERENCE MATERIALS
number.
Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Description Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Output Coding Transfer Functions Analog Input Structure Track-and-Hold Section Typical Connection Diagram Analog Input Single-Ended Inputs True Differential Mode Pseudo Differential Inputs Driver Amplifier Choice Registers Addressing Registers Control Register Sequence Register Range Register Sequencer Operation Reference VDRIVE Modes of Operation Normal Mode Full Shutdown Mode Autoshutdown Mode Autostandby Mode Power vs. Throughput Rate Serial Interface Microprocessor Interfacing AD7324 to ADSP-21xx AD7324 to ADSP-BF53x Application Hints Layout and Grounding Power Supply Configuration Outline Dimensions Ordering Guide
