Datasheet AD9446 (Analog Devices) - 4
Description16-Bit, 80 MSPS / 100 MSPS A/D Converter
Pages / Page37 / 4 — AD9446. SPECIFICATIONS DC SPECIFICATIONS. Table 1. AD9446BSVZ-80. …
File Format / SizePDF / 718 Kb
AD9446. SPECIFICATIONS DC SPECIFICATIONS. Table 1. AD9446BSVZ-80. AD9446BSVZ-100. Parameter. Temp. Min Typ Max Min Typ Max Unit
AD9446 SPECIFICATIONS DC SPECIFICATIONS Table 1 AD9446BSVZ-80 AD9446BSVZ-100 Parameter Temp Min Typ Max Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 16
AVDD1 = 3.3 V, AVDD2 = 5.0 V, DRVDD = 3.3 V, LVDS mode, specified minimum sampling rate, 3.2 V p-p differential input, internal trimmed reference (1.6 V mode), AIN = −1.0 dBFS, DCS on, unless otherwise noted.
Table 1. AD9446BSVZ-80 AD9446BSVZ-100 Parameter Temp Min Typ Max Min Typ Max Unit
RESOLUTION Full 16 16 Bits ACCURACY No Missing Codes Full Guaranteed Guaranteed Offset Error Full −5 ±0.1 +5 −5 ±0.1 +5 mV Gain Error Full −3 ±0.6 +3 −3 ±0.5 +3 % FSR 25°C −2 ±0.3 +2 −2 ±0.3 +2 % FSR Differential Nonlinearity (DNL)1 Full −0.75 ±0.4 +0.75 −0.85 ±0.4 +0.85 LSB Integral Nonlinearity (INL)1 25°C −5 ±3.0 +5 −6 ±3.0 +6 LSB VOLTAGE REFERENCE Output Voltage1 VREF = 1.6 V (3.2 V p-p Analog Input Range) Full 1.6 1.6 V Load Regulation @ 1.0 mA Full ±2 ±2 mV Reference Input Current (External 1.6 V Reference) Full μA INPUT REFERRED NOISE 25°C 1.5 1.9 LSB rms ANALOG INPUT Input Span VREF = 1.6 V Full 3.2 3.2 V p-p VREF = 1.0 V (External) Full 2.0 2.0 V p-p Internal Input Common-Mode Voltage Full 3.5 3.5 V External Input Common-Mode Voltage Full 3.2 3.8 3.2 3.8 V Input Resistance2 Full 1 1 kΩ Input Capacitance2 Full 6 6 pF POWER SUPPLIES Supply Voltage AVDD1 Full 3.14 3.3 3.46 3.14 3.3 3.46 V AVDD2 Full 4.75 5.0 5.25 4.75 5.0 5.25 V DRVDD—LVDS Outputs Full 3.0 3.3 3.6 3.0 3.3 3.6 V DRVDD—CMOS Outputs Full 3.0 3.3 3.6 3.0 3.3 3.6 V Supply Current I 1 AVDD Full 335 365 368 401 mA I 1 AVDD2 Full 204 234 223 255 mA I 1 DRVDD —LVDS Outputs Full 68 75 69 75 mA I 1 DRVDD —CMOS Outputs Full 14 14 mA PSRR Offset Full 1 1 mV/V Gain Full 0.2 0.2 %/V POWER CONSUMPTION LVDS Outputs Full 2.4 2.6 2.6 2.8 W CMOS Outputs (DC Input) Full 2.2 2.3 W 1 Measured at the maximum clock rate, fIN = 15 MHz, full-scale sine wave, with a 100 Ω differential termination on each pair of output bits for LVDS output mode and approximately 5 pF loading on each output bit for CMOS output mode. 2 Input capacitance or resistance refers to the effective impedance between one differential input pin and AGND. Refer to Figure 6 for the equivalent analog input structure. Rev. 0 | Page 3 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TERMINOLOGY PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT AND REFERENCE OVERVIEW Internal Reference Connection Internal Reference Trim External Reference Operation Analog Inputs CLOCK INPUT CONSIDERATIONS Jitter Considerations POWER CONSIDERATIONS DIGITAL OUTPUTS LVDS Mode CMOS Mode TIMING OPERATIONAL MODE SELECTION Data Format Select Output Mode Select Duty Cycle Stabilizer EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
