Datasheet AD9446 (Analog Devices) - 6
Description | 16-Bit, 80 MSPS / 100 MSPS A/D Converter |
Pages / Page | 37 / 6 — AD9446. AD9446BSVZ-80. AD9446BSVZ-100. Parameter. Temp. Min Typ Max Min … |
File Format / Size | PDF / 718 Kb |
AD9446. AD9446BSVZ-80. AD9446BSVZ-100. Parameter. Temp. Min Typ Max Min Typ Max Unit
AD9446 AD9446BSVZ-80 AD9446BSVZ-100 Parameter Temp Min Typ Max Min Typ Max Unit
SPURIOUS-FREE DYNAMIC RANGE (SFDR, Second or Third Harmonic) fIN = 10 MHz 25°C 82 90 82 92 dBc fIN = 30 MHz 25°C 82 89 82 89 dBc Full 80 79 dBc fIN = 70 MHz 25°C 80 87 81 89 dBc Full 79 77 dBc fIN = 92 MHz 25°C 84 84 dBc fIN = 125 MHz 25°C 80 83 dBc fIN = 170 MHz 25°C 66 74 dBc fIN = 10 MHz (2 V p-p Input) 25°C 92 94 dBc fIN = 30 MHz (2 V p-p Input) 25°C 93 92 dBc fIN = 70 MHz (2 V p-p Input) 25°C 92 92 dBc fIN = 92 MHz (2 V p-p Input) 25°C 90 89 dBc fIN = 125 MHz (2 V p-p Input) 25°C 85 87 dBc fIN = 170 MHz (2 V p-p Input) 25°C 77 82 dBc WORST SPUR EXCLUDING SECOND OR THIRD HARMONICS fIN = 10 MHz 25°C −98 −89 −96 −91 dBc fIN = 30 MHz 25°C −97 −89 −97 −89 dBc Full −89 −87 dBc fIN = 70 MHz 25°C −98 −90 −96 −90 dBc Full −89 −88 dBc fIN = 92 MHz 25°C −98 −95 dBc fIN = 125 MHz 25°C −96 −96 dBc fIN = 170 MHz 25°C −95 −92 dBc fIN = 10 MHz (2 V p-p Input) 25°C −97 −93 dBc fIN = 30 MHz (2 V p-p Input) 25°C −97 −96 dBc fIN = 70 MHz (2 V p-p Input) 25°C −94 −94 dBc fIN = 92 MHz (2 V p-p Input) 25°C −97 −99 dBc fIN = 125 MHz (2 V p-p Input) 25°C −97 −95 dBc fIN = 170 MHz (2 V p-p Input) 25°C −93 −95 dBc TWO-TONE SFDR fIN = 10.8 MHz @ −7 dBFS, 25°C 96 95 dBFS 9.8 MHz @ −7 dBFS fIN = 70.3 MHz @ −7 dBFS, 25°C 92 92 dBFS 69.3 MHz @ −7 dBFS ANALOG BANDWIDTH Full 325 540 MHz Rev. 0 | Page 5 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TERMINOLOGY PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT AND REFERENCE OVERVIEW Internal Reference Connection Internal Reference Trim External Reference Operation Analog Inputs CLOCK INPUT CONSIDERATIONS Jitter Considerations POWER CONSIDERATIONS DIGITAL OUTPUTS LVDS Mode CMOS Mode TIMING OPERATIONAL MODE SELECTION Data Format Select Output Mode Select Duty Cycle Stabilizer EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
