Datasheet AD9446 (Analog Devices) - 9
Description16-Bit, 80 MSPS / 100 MSPS A/D Converter
Pages / Page37 / 9 — AD9446. ABSOLUTE MAXIMUM RATINGS. Table 5. With Respect. Parameter. …
File Format / SizePDF / 718 Kb
AD9446. ABSOLUTE MAXIMUM RATINGS. Table 5. With Respect. Parameter. Rating. THERMAL RESISTANCE. Table 6. Package Type. θJA. θJB. θJC. Unit
AD9446 ABSOLUTE MAXIMUM RATINGS Table 5 With Respect Parameter Rating THERMAL RESISTANCE Table 6 Package Type θJA θJB θJC Unit
AD9446 ABSOLUTE MAXIMUM RATINGS Table 5.
Stresses above those listed under Absolute Maximum Ratings
With Respect
may cause permanent damage to the device. This is a stress
Parameter to Rating
rating only; functional operation of the device at these or any ELECTRICAL other conditions above those indicated in the operational AVDD1 AGND −0.3 V to +4 V section of this specification is not implied. Exposure to absolute AVDD2 AGND −0.3 V to +6 V maximum rating conditions for extended periods may affect DRVDD DGND −0.3 V to +4 V device reliability. AGND DGND −0.3 V to +0.3 V
THERMAL RESISTANCE
AVDD1 DRVDD −4 V to +4 V AVDD2 DRVDD −4 V to +6 V The heat sink of the AD9446 package must be soldered to AVDD2 AVDD1 −4 V to +6 V ground. D0± to D15± DGND –0.3 V to DRVDD + 0.3 V
Table 6.
CLK+/CLK− AGND –0.3 V to AVDD1 + 0.3 V
OUTPUT MODE, AGND –0.3 V to AVDD1 + 0.3 V 100-lead TQFP/EP 19.8 8.3 2 °C/W DCS MODE, DFS VIN+, VIN− AGND –0.3 V to AVDD2 + 0.3 V Typical θJA = 19.8°C/W (heat sink soldered) for multilayer VREF AGND –0.3 V to AVDD1 + 0.3 V board in still air. SENSE AGND –0.3 V to AVDD1 + 0.3 V REFT, REFB AGND –0.3 V to AVDD1 + 0.3 V Typical θJB = 8.3°C/W (heat sink soldered) for multilayer board ENVIRONMENTAL in still air. Storage Temperature –65°C to +125°C Range Typical θJC = 2°C/W (junction to exposed heat sink) represents Operating Temperature –40°C to +85°C the thermal resistance through heat sink path. Range Lead Temperature 300°C Airflow increases heat dissipation, effectively reducing θJA. Also, (Soldering 10 sec) more metal directly in contact with the package leads from Junction Temperature 150°C metal traces through holes, ground, and power planes reduces the θ JA. It is required that the exposed heat sink be soldered to the ground plane.
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. 0 | Page 8 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TERMINOLOGY PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT AND REFERENCE OVERVIEW Internal Reference Connection Internal Reference Trim External Reference Operation Analog Inputs CLOCK INPUT CONSIDERATIONS Jitter Considerations POWER CONSIDERATIONS DIGITAL OUTPUTS LVDS Mode CMOS Mode TIMING OPERATIONAL MODE SELECTION Data Format Select Output Mode Select Duty Cycle Stabilizer EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
