AD9237* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017COMPARABLE PARTSTOOLS AND SIMULATIONS View a parametric search of comparable parts. • Visual Analog • AD9237 IBIS Models DOCUMENTATION • AD9237LFCSP Analog Input S-Parameter Data Application Notes • AN-1142: Techniques for High Speed ADC PCB Layout REFERENCE MATERIALS • AN-282: Fundamentals of Sampled Data Systems Technical Articles • AN-345: Grounding for Low-and-High-Frequency Circuits • Correlating High-Speed ADC Performance to Multicarrier • AN-501: Aperture Uncertainty and ADC System 3G Requirements Performance • Matching An ADC To A Transformer • AN-715: A First Approach to IBIS Models: What They Are • MS-2210: Designing Power Supplies for High Speed ADC and How They Are Generated • AN-737: How ADIsimADC Models an ADC DESIGN RESOURCES • AN-741: Little Known Characteristics of Phase Noise • AD9237 Material Declaration • AN-742: Frequency Domain Response of Switched- • PCN-PDN Information Capacitor ADCs • Quality And Reliability • AN-756: Sampled Systems and the Effects of Clock Phase • Symbols and Footprints Noise and Jitter • AN-803: Pin Compatible High Speed ADCs Simplify Design DISCUSSIONS Tasks • AN-827: A Resonant Approach to Interfacing Amplifiers to View all AD9237 EngineerZone Discussions. Switched-Capacitor ADCs • AN-835: Understanding High Speed ADC Testing and SAMPLE AND BUY Evaluation Visit the product page to see pricing options. • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual TECHNICAL SUPPORT • AN-935: Designing an ADC Transformer-Coupled Front Submit a technical question or find your regional support End number. Data Sheet • AD9237: 12-Bit, 20 MSPS/40 MSPS/65 MSPS 3 V Low DOCUMENT FEEDBACK Power A/D Converter Data Sheet Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline Features Applications Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications DC Specifications Digital Specifications AC Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Terminology Equivalent Circuits Typical Performance Characteristics Applying the AD9237 Theory of Operation Analog Input and Reference Overview Differential Input Configurations Single-Ended Input Configuration Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Power Dissipation, Power Scaling, and Standby Mode Digital Outputs Operational Mode Selection Out of Range (OTR) Digital Output Enable Function (OE) Timing Outline Dimensions Ordering Guide
