Datasheet AD7328 (Analog Devices) - 2
DescriptionSoftware Selectable, True Bipolar Input, 8-Channel, 12-Bit Plus Sign A/D Converter
Pages / Page37 / 2 — AD7328* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 773 Kb
AD7328* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
AD7328* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
View a parametric search of comparable parts.
Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
EVALUATION KITS
• AD7328 Evaluation Board
DESIGN RESOURCES
• AD7328 Material Declaration
DOCUMENTATION
• PCN-PDN Information
Data Sheet
• Quality And Reliability • AD7328: 8-Channel, Software-Selectable,True Bipolar • Symbols and Footprints Input, 12-Bit Plus Sign ADC Data Sheet
User Guides DISCUSSIONS
• UG-419: Evaluating the AD7327/AD7328 View all AD7328 EngineerZone Discussions.
SOFTWARE AND SYSTEMS REQUIREMENTS SAMPLE AND BUY
• AD7328 - Microcontroller No-OS Driver Visit the product page to see pricing options. • AD7328 Evaluation Software • AD7328 FMC-SDP Interposer & Evaluation Board / Xilinx
TECHNICAL SUPPORT
KC705 Reference Design Submit a technical question or find your regional support • BeMicro FPGA Project for AD7328 with Nios driver number.
REFERENCE DESIGNS DOCUMENT FEEDBACK
• CN0047 Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline Features General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Output Coding Transfer Functions Analog Input Structure Track-and-Hold Section Typical Connection Diagram Analog Input Single-Ended Inputs True Differential Mode Pseudo Differential Inputs Driver Amplifier Choice Registers Addressing Registers Control Register Sequence Register Range Registers Sequencer Operation Reference VDRIVE Temperature Indicator Modes of Operation Normal Mode (PM1 = PM0 = 0) Full Shutdown Mode (PM1 = PM0 = 1) Autoshutdown Mode (PM1 = 1, PM0 = 0) Autostandby Mode (PM1 = 0, PM0 = 1) Power vs. Throughput Rate Serial Interface Microprocessor Interfacing AD7328 to ADSP-21xx AD7328 to ADSP-BF53x Applications Information Layout and Grounding Power Supply Configuration Outline Dimensions Ordering Guide
