Datasheet AD7328 (Analog Devices) - 8
DescriptionSoftware Selectable, True Bipolar Input, 8-Channel, 12-Bit Plus Sign A/D Converter
Pages / Page37 / 8 — Data Sheet. AD7328. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter. Rating. …
RevisionC
File Format / SizePDF / 773 Kb
Data Sheet. AD7328. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter. Rating. ESD CAUTION
Data Sheet AD7328 ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
link to page 34 link to page 8 link to page 8
TA = 25°C, unless otherwise noted
Table 4. Parameter Rating
Stresses above those listed under Absolute Maximum Ratings V may cause permanent damage to the device. This is a stress DD to AGND, DGND −0.3 V to +16.5 V V rating only; functional operation of the device at these or any SS to AGND, DGND +0.3 V to −16.5 V V other conditions above those indicated in the operational DD to VCC VCC − 0.3 V to +16.5 V V section of this specification is not implied. Exposure to absolute CC to AGND, DGND −0.3 V to +7 V V maximum rating conditions for extended periods may affect DRIVE to AGND, DGND −0.3 V to +7 V AGND to DGND −0.3 V to +0.3 V device reliability. Analog Input Voltage to AGND1 V SS − 0.3 V to VDD + 0.3 V Digital Input Voltage to DGND −0.3 V to +7 V
ESD CAUTION
Digital Output Voltage to GND −0.3 V to VDRIVE + 0.3 V REFIN to AGND −0.3 V to VCC + 0.3 V Input Current to Any Pin ±10 mA Except Supplies2 Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C TSSOP Package θJA Thermal Impedance 143°C/W θJC Thermal Impedance 45°C/W Pb-Free Temperature, Soldering Reflow 260(0)°C ESD 2.5 kV 1 If the analog inputs are driven from alternative VDD and VSS supply circuitry, Schottky diodes should be placed in series with the VDD and VSS supplies of the AD7328 (see the Power Supply Configuration section). 2 Transient currents of up to 100 mA do not cause SCR latch-up. Rev. C | Page 7 of 36 Document Outline Features General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Output Coding Transfer Functions Analog Input Structure Track-and-Hold Section Typical Connection Diagram Analog Input Single-Ended Inputs True Differential Mode Pseudo Differential Inputs Driver Amplifier Choice Registers Addressing Registers Control Register Sequence Register Range Registers Sequencer Operation Reference VDRIVE Temperature Indicator Modes of Operation Normal Mode (PM1 = PM0 = 0) Full Shutdown Mode (PM1 = PM0 = 1) Autoshutdown Mode (PM1 = 1, PM0 = 0) Autostandby Mode (PM1 = 0, PM0 = 1) Power vs. Throughput Rate Serial Interface Microprocessor Interfacing AD7328 to ADSP-21xx AD7328 to ADSP-BF53x Applications Information Layout and Grounding Power Supply Configuration Outline Dimensions Ordering Guide
