Datasheet AD7273, AD7274 (Analog Devices) - 9
Description3 MSPS 12-Bit A/D Converter in TSOT and MSOP Packages
Pages / Page28 / 9 — AD7273/AD7274. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameters Ratings. ESD …
File Format / SizePDF / 410 Kb
AD7273/AD7274. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameters Ratings. ESD CAUTION
AD7273/AD7274 ABSOLUTE MAXIMUM RATINGS Table 5 Parameters Ratings ESD CAUTION
link to page 9
Table 5.
Stresses above those listed under Absolute Maximum Ratings
Parameters Ratings
may cause permanent damage to the device. This is a stress VDD to AGND/DGND −0.3 V to +6 V rating only; functional operation of the device at these or any Analog Input Voltage to AGND −0.3 V to VDD + 0.3 V other conditions above those indicated in the operational Digital Input Voltage to DGND −0.3 V to +6 V section of this specification is not implied. Exposure to absolute Digital Output Voltage to DGND −0.3 V to VDD + 0.3 V maximum rating conditions for extended periods may affect Input Current to Any Pin Except Supplies1 ±10 mA device reliability. Operating Temperature Range Commercial (B Grade) −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C 6-Lead TSOT Package θJA Thermal Impedance 230°C/W θJC Thermal Impedance 92°C/W 8-Lead MSOP Package θJA Thermal Impedance 205.9°C/W θJC Thermal Impedance 43.74°C/W Lead Temperature Soldering Reflow (10 to 30 sec) 255°C Lead Temperature Soldering Reflow (10 to 30 sec) 260°C ESD 1.5 kV 1 Transient currents of up to 100 mA cause SCR latch-up.
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. 0 | Page 9 of 28 Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS AD7274 SPECIFICATIONS AD7273 SPECIFICATIONS TIMING SPECIFICATIONS TIMING EXAMPLES Timing Example 1 Timing Example 2 ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY CIRCUIT INFORMATION CONVERTER OPERATION ADC TRANSFER FUNCTION TYPICAL CONNECTION DIAGRAM ANALOG INPUT DIGITAL INPUTS MODES OF OPERATION NORMAL MODE PARTIAL POWER-DOWN MODE FULL POWER-DOWN MODE POWER-UP TIMES POWER VS. THROUGHPUT RATE SERIAL INTERFACE MICROPROCESSOR INTERFACING AD7273/AD7274 to ADSP-BF53x APPLICATION HINTS GROUNDING AND LAYOUT EVALUATING THE AD7273/AD7274 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
