Datasheet AD7266 (Analog Devices) - 2
DescriptionDifferential/Single-Ended Input, Dual, Simultaneous Sampling, 2 MSPS, 12-Bit, 3-Channel SAR A/D Converter
Pages / Page29 / 2 — AD7266* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 702 Kb
AD7266* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Press. EVALUATION KITS
AD7266* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Press EVALUATION KITS
View a parametric search of comparable parts.
Press
• Dual-Supply, High-Precision Operational Amplifier
EVALUATION KITS
Designed for Front-End Amplifier Applications • AD7266 Evaluation Board
Product Selection Guide
• SAR ADC & Driver Quick-Match Guide
DOCUMENTATION Technical Articles Application Notes
• MS-1779: Nine Often Overlooked ADC Specifications • AN-742: Frequency Domain Response of Switched- • MS-2210: Designing Power Supplies for High Speed ADC Capacitor ADCs
Tutorials
• AN-931: Understanding PulSAR ADC Support Circuitry • MT-002: What the Nyquist Criterion Means to Your
Data Sheet
Sampled Data System Design • AD7266: Differential/Single-Ended Input, Dual 2 MSPS, 12- • MT-031: Grounding Data Converters and Solving the Bit, 3-Channel SAR ADC Data Sheet Mystery of "AGND" and "DGND"
Technical Books
• The Data Conversion Handbook, 2005
DESIGN RESOURCES
• AD7266 Material Declaration
SOFTWARE AND SYSTEMS REQUIREMENTS
• PCN-PDN Information • AD7266 Differential/Single-Ended Input, Dual, • Quality And Reliability Simultaneous Sampling, 2 MSPS, 12-Bit, 3-Channel SAR A/ • Symbols and Footprints D Converter Linux Driver • BeMicro FPGA Project for CN0187 with Nios driver
DISCUSSIONS
• CN0187 FMC-SDP Interposer & Evaluation Board / Xilinx View all AD7266 EngineerZone Discussions. KC705 Reference Design
SAMPLE AND BUY REFERENCE DESIGNS
Visit the product page to see pricing options. • CN0039 • CN0187
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION ANALOG INPUT STRUCTURE ANALOG INPUTS Single-Ended Mode Differential Mode Driving Differential Inputs Using an Op Amp Pair Pseudo Differential Mode ANALOG INPUT SELECTION OUTPUT CODING TRANSFER FUNCTIONS DIGITAL INPUTS VDRIVE MODES OF OPERATION NORMAL MODE PARTIAL POWER-DOWN MODE FULL POWER-DOWN MODE POWER-UP TIMES POWER vs. THROUGHPUT RATE SERIAL INTERFACE MICROPROCESSOR INTERFACING AD7266 TO ADSP-218x AD7266 TO ADSP-BF53x AD7266 TO TMS320C541 AD7266 TO DSP563xx APPLICATION HINTS GROUNDING AND LAYOUT PCB DESIGN GUIDELINES FOR LFCSP EVALUATING THE AD7266 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
