Datasheet AD9289 (Analog Devices) - 7
DescriptionQuad 8-Bit, 65 MSPS, Serial LVDS A/D Converter
Pages / Page33 / 7 — AD9289. ABSOLUTE MAXIMUM RATINGS. Table 5. EXPLANATION OF TEST LEVELS. …
File Format / SizePDF / 934 Kb
AD9289. ABSOLUTE MAXIMUM RATINGS. Table 5. EXPLANATION OF TEST LEVELS. With Respect. Parameter. Min. Max. Unit. ESD CAUTION
AD9289 ABSOLUTE MAXIMUM RATINGS Table 5 EXPLANATION OF TEST LEVELS With Respect Parameter Min Max Unit ESD CAUTION
link to page 8
AD9289 ABSOLUTE MAXIMUM RATINGS Table 5. EXPLANATION OF TEST LEVELS With Respect
I. 100% production tested.
Parameter To Min Max Unit
II. 100% production tested at 25°C and guaranteed by design ELECTRICAL and characterization at specified temperatures. AVDD AGND –0.3 +3.9 V DRVDD DRGND –0.3 +3.9 V III. Sample tested only. AGND DRGND –0.3 +0.3 V AVDD DRVDD –3.9 +3.9 V IV. Parameter is guaranteed by design and characterization Digital Outputs (D1+, DRGND –0.3 DRVDD V testing. D1–, DCO+, DCO–, FCO+, FCO–) V. Parameter is a typical value only. LOCK, LVDSBIAS DRGND –0.3 DRVDD V VI. 100% production tested at 25°C and guaranteed by design CLK+, CLK– AGND –0.3 AVDD V and characterization for industrial temperature range. VIN+, VIN– AGND –0.3 AVDD V PDWN, DFS, DTP AGND –0.3 AVDD V REFT, REFB, AGND –0.3 AVDD V SHARED_REF, CML VREF, SENSE AGND –0.3 AVDD V Stresses above those listed under Absolute Maximum Ratings ENVIRONMENTAL may cause permanent damage to the device. This is a stress Operating –40 +85 °C Temperature Range rating only; functional operation of the device at these or any (Ambient) other conditions above those listed in the operational sections Maximum Junction 150 °C of this specification is not implied. Exposure to absolute Temperature maximum rating conditions for extended periods may affect Lead Temperature 300 °C device reliability. (Soldering, 10 sec) Storage –65 +150 °C Temperature Range (Ambient) Thermal 40 °C/W Impedance1 1 θJA for a 4-layer PCB with solid ground plane in still air.
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. 0 | Page 6 of 32 Document Outline FEATURES PRODUCT DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION ANALOG INPUT AND REFERENCE OVERVIEW Differential Input Configurations Single-Ended Input Configuration CLOCK INPUT AND CONSIDERATIONS Power Dissipation and Standby Mode Digital Outputs Timing Pin CML Pin DTP Pin Voltage Reference Internal Reference Connection External Reference Operation Power and Ground Recommendations EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
