Datasheet AD9480 (Analog Devices) - 8
Description8-Bit, 250 MSPS, 3.3 V A/D Converter
Pages / Page29 / 8 — AD9480. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter. Min Rating. Max …
File Format / SizePDF / 650 Kb
AD9480. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter. Min Rating. Max Rating. EXPLANATION OF TEST LEVELS. Table 6. Level Descriptions
AD9480 ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Min Rating Max Rating EXPLANATION OF TEST LEVELS Table 6 Level Descriptions
Thermal impedance (θJA) = 46.4°C/W (4-layer PCB).
Table 5. Parameter Min Rating Max Rating
Stresses above those listed under Absolute Maximum Ratings ELECTRICAL may cause permanent damage to the device. This is a stress AVDD −0.5 V +4.0 V rating only; functional operation of the device at these or any (With Respect to AGND) other conditions above those indicated in the operational DRVDD −0.5 V +4.0 V section of this specification is not implied. Exposure to absolute (With Respect to DRGND) maximum rating conditions for extended periods may affect AGND −0.5 V +0.5 V (With Respect to DRGND) device reliability. Digital I/O −0.5 V DRVDD + 0.5 V (With Respect to DRGND) Analog Inputs −0.5 V AVDD + 0.5 V (With Respect to AGND) ENVIRONMENTAL Operating Temperature −40°C 85°C Junction Temperature 150°C Case Temperature 150°C Storage Temperature 150°C
EXPLANATION OF TEST LEVELS Table 6. Level Descriptions
I 100% production tested. II 100% production tested at 25°C and guaranteed by design and characterization at specified temperatures. III Sample tested only. IV Parameter is guaranteed by design and characterization testing. V Parameter is a typical value only. VI 100% production tested at 25°C and guaranteed by design and characterization for industrial temperature range.
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. A | Page 7 of 28 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY DC SPECIFICATIONS DIGITAL SPECIFICATIONS AC SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS APPLICATION NOTES CLOCKING THE AD9480 ANALOG INPUTS VOLTAGE REFERENCE Fixed Reference External Reference Programmable Reference DIGITAL OUTPUTS OUTPUT CODING INTERLEAVING TWO AD9480s DATA CLOCK OUT POWER-DOWN AD9480 EVALUATION BOARD POWER CONNECTOR ANALOG INPUTS GAIN OPTIONAL OPERATIONAL AMPLIFIER CLOCK OPTIONAL CLOCK BUFFER OPTIONAL XTAL VOLTAGE REFERENCE DATA OUTPUTS EVALUATION BOARD BILL OF MATERIALS (BOM) PCB SCHEMATICS PCB LAYERS OUTLINE DIMENSIONS ORDERING GUIDE
