Datasheet AD7677 (Analog Devices) - 2
Description16-Bit, 1 LSB INL, 1 MSPS Differential PulSAR ADC
Pages / Page21 / 2 — AD7677* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 384 Kb
AD7677* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD7677* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD7677 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD7677 Evaluation Kit • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all AD7677 EngineerZone Discussions. • AN-931: Understanding PulSAR ADC Support Circuitry • AN-932: Power Supply Sequencing
SAMPLE AND BUY Data Sheet
Visit the product page to see pricing options. • AD7677: 16-Bit, 1 LSB, 1 MSPS Differential ADC Data Sheet
Product Highlight TECHNICAL SUPPORT
• 8- to 18-Bit SAR ADCs ... From the Leader in High Submit a technical question or find your regional support Performance Analog number.
REFERENCE MATERIALS DOCUMENT FEEDBACK Technical Articles
Submit feedback for this data sheet. • MS-2210: Designing Power Supplies for High Speed ADC
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PulSAR Selection GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS Table I. Serial Clock Timings in Master Read after Convert ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN FUNCTION DESCRIPTIONS PIN CONFIGURATION Typical Performance Characteristics CIRCUIT INFORMATION CONVERTER OPERATION Modes of Operation Transfer Functions TYPICAL CONNECTION DIAGRAM Analog Inputs Single to Differential Driver Driver Amplifier Choice Voltage Reference Input Power Supply POWER DISSIPATION CONVERSION CONTROL DIGITAL INTERFACE PARALLEL INTERFACE SERIAL INTERFACE MASTER SERIAL INTERFACE Internal Clock SLAVE SERIAL INTERFACE External Clock External Discontinuous Clock Data Read after Conversion External Clock Data Read During Conversion MICROPROCESSOR INTERFACING SPI Interface (MC68HC11) ADSP-21065L in Master Serial Interface APPLICATION HINTS Layout Evaluating the AD7677 Performance OUTLINE DIMENSIONS Revision History
