Datasheet AD7490 (Analog Devices) - 6
Description16-Channel, 1MSPS, 12-Bit ADC with Sequencer in 28-Lead TSSOP
Pages / Page29 / 6 — Data Sheet. AD7490. TIMING SPECIFICATIONS. Table 2. Timing …
RevisionD
File Format / SizePDF / 759 Kb
Data Sheet. AD7490. TIMING SPECIFICATIONS. Table 2. Timing Specifications1. Limit at TMIN, TMAX. Parameter VDD = 3 V. VDD = 5 V. Unit
Data Sheet AD7490 TIMING SPECIFICATIONS Table 2 Timing Specifications1 Limit at TMIN, TMAX Parameter VDD = 3 V VDD = 5 V Unit
link to page 6 link to page 23 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6
VDD = 2.7 V to 5.25 V, VDRIVE ≤ VDD, REFIN = 2.5 V; TA = TMIN to TMAX, unless otherwise noted.
Table 2. Timing Specifications1 Limit at TMIN, TMAX Parameter VDD = 3 V VDD = 5 V Unit Description
f 2 SCLK 10 10 kHz min 16 20 MHz max tCONVERT 16 × tSCLK 16 × tSCLK tQUIET 50 50 ns min Minimum quiet time required between bus relinquish and start of next conversion t2 12 10 ns min CS to SCLK setup time t 3 3 20 14 ns max Delay from CS until DOUT three-state disabled t3b4 30 20 ns max Delay from CS to DOUT valid t 3 4 60 40 ns max Data access time after SCLK falling edge t5 0.4 × tSCLK 0.4 × tSCLK ns min SCLK low pulse width t6 0.4 × tSCLK 0.4 × tSCLK ns min SCLK high pulse width t7 15 15 ns min SCLK to DOUT valid hold time t 5 8 15/50 15/50 ns min/max SCLK falling edge to DOUT high impedance t9 20 20 ns min DIN setup time prior to SCLK falling edge t10 5 5 ns min DIN hold time after SCLK falling edge t11 20 20 ns min 16th SCLK falling edge to CS high t12 1 1 µs max Power-up time from full power-down/auto shutdown/auto standby modes 1 Guaranteed by characterization. All input signals are specified with tR = tF = 5 ns (10% to 90% of VDD) and timed from a voltage level of 1.6 V (see Figure 2). The 3 V operating range spans from 2.7 V to 3.6 V. The 5 V operating range spans from 4.75 V to 5.25 V. 2 The mark/space ratio for the SCLK input is 40/60 to 60/40. The maximum SCLK frequency is 16 MHz with VDD = 3 V to give a throughput of 870 kSPS. Care must be taken when interfacing to account for data access time, t4, and the setup time required for the user’s processor. These two times determine the maximum SCLK frequency with which the user’s system can operate (see the Serial Interface section). 3 Measured with the load circuit of Figure 2 and defined as the time required for the output to cross 0.4 V or 0.7 VDRIVE . 4 t3b represents a worst-case figure for having ADD3 available on the DOUT line, that is, if the AD7490 goes back into three-state at the end of a conversion and some other device takes control of the bus between conversions, the user has to wait a maximum time of t3b before having ADD3 valid on the DOUT line. If the DOUT line is weakly driven to ADD3 between conversions, the user typically has to wait 17 ns at 3 V and 12 ns at 5 V after the CS falling edge before seeing ADD3 valid on DOUT. 5 t8 is derived from the measured time taken by the data outputs to change 0.5 V when loaded with the circuit of Figure 2. The measured number is then extrapolated back to remove the effects of charging or discharging the 25 pF capacitor. This means that the time, t8, quoted in the timing characteristics, is the true bus relinquish time of the part and is independent of the bus loading.
200µA IOL TO OUTPUT 1.6V PIN CL 25pF
002
200µA IOH
02691- Figure 2. Load Circuit for Digital Output Timing Specifications Rev. D | Page 5 of 28 Document Outline Features Functional Block Diagram General Description Product Highlights Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Internal Register Structure Control Register Sequencer Operation Shadow Register Theory of Operation Circuit Information Converter Operation Analog Input ADC Transfer Function Handling Bipolar Input Signals Typical Connection Diagram Analog Input Channels Digital Input VDRIVE Reference Section Modes of Operation Normal Mode (PM1 = PM0 = 1) Full Shutdown (PM1 = 1, PM0 = 0) Auto Shutdown (PM1 = 0, PM0 = 1) Auto Standby (PM1 = PM0 = 0) Powering Up the AD7490 Serial Interface Power vs. Throughput Rate Microprocessor Interfacing AD7490 to TMS320C541 AD7490 to ADSP-21xx AD7490 to DSP563xx Application Hints Grounding and Layout PCB Design Guidelines for Chip Scale Package Evaluating the AD7490 Performance Outline Dimensions Ordering Guide
