link to page 9 link to page 9 AD7490Data SheetTYPICAL PERFORMANCE CHARACTERISTICS Figure 5 shows a typical FFT plot for the AD7490 at 1 MSPS sample rate and 50 kHz input frequency. Figure 7 shows the power supply rejection ratio vs. supply ripple frequency for the AD7490. The power supply rejection ratio is defined as the ratio of the power in the ADC output at full-scale frequency f, to the power of a 200 mV p-p sine wave applied to the ADC VDD supply of frequency fS. PSRR(dB) Pf =10 × log Pfs where: Pf is equal to the power at frequency f in ADC output. PfS is equal to power at frequency fS coupled onto the ADC VDD supply input. Here, a 200 mV p-p sine wave is coupled onto the VDD supply. 10 nF decoupling was used on the supply, and a 1 µF decoupling capacitor was used on the REFIN pin. 5–208192 POINT FFTVDD = 3V/5V, 10nF CAPfSAMPLE = 1MSPS200mV p-p SINE WAVE ON VDDf–30–15IN = 50kHZREFIN = 2.5V, 1µF CAPSINAD = 70.697dBTA = 25°CTHD = –79.171dB SFDR = –79.93dB–40–35B) –50B) dd–55NR (RR (SS –60P–75–70VDD = 5V–95–80VDD = 3V–90050100150200250300350400450500 004 0100k 200k 300k 400k 500k 600k 700k 800k 900k1M 006 FREQUENCY (kHz)INPUT FREQUENCY (Hz) 02691- 02691- Figure 5. Dynamic Performance at 1 MSPS Figure 7. PSRR vs. Supply Ripple Frequency 75–50fS = MAX THROUGHPUT TA = 25°CV–55DD = VDRIVE = 5.25VRANGE = 0V TO REFINVDD = VDRIVE = 4.75VVDD = VDRIVE = 2.7V70–60–65VDD = VDRIVE = 3.6VB) dB) d65–70VDD = VDRIVE = 3.6VHD (INAD (TS–7560–80VDD = VDRIVE = 4.75VfVVS = MAX THROUGHPUTDD = VDRIVE = 2.7V–85DD = VDRIVE = 5.25VTA = 25°C RANGE = 0V TO REFIN55–90101001000 005 101001000 007 INPUT FREQUENCY (kHz)INPUT FREQUENCY (kHz) 02691- 02691- Figure 6. SINAD vs. Analog Input Frequency Figure 8. THD vs. Analog Input Frequency for Various Supply Voltages at 1 MSPS for Various Supply Voltages at 1 MSPS Rev. D | Page 8 of 28 Document Outline Features Functional Block Diagram General Description Product Highlights Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Internal Register Structure Control Register Sequencer Operation Shadow Register Theory of Operation Circuit Information Converter Operation Analog Input ADC Transfer Function Handling Bipolar Input Signals Typical Connection Diagram Analog Input Channels Digital Input VDRIVE Reference Section Modes of Operation Normal Mode (PM1 = PM0 = 1) Full Shutdown (PM1 = 1, PM0 = 0) Auto Shutdown (PM1 = 0, PM0 = 1) Auto Standby (PM1 = PM0 = 0) Powering Up the AD7490 Serial Interface Power vs. Throughput Rate Microprocessor Interfacing AD7490 to TMS320C541 AD7490 to ADSP-21xx AD7490 to DSP563xx Application Hints Grounding and Layout PCB Design Guidelines for Chip Scale Package Evaluating the AD7490 Performance Outline Dimensions Ordering Guide
