Datasheet AD6645 (Analog Devices) - 7
Description14-Bit, 80 MSPS/105 MSPS A/D Converter
Pages / Page25 / 7 — AD6645. Data Sheet. AD6645ASQ-80/. AD6645ASQ-105/. Test. AD6645ASV-80. …
RevisionE
AD6645. Data Sheet. AD6645ASQ-80/. AD6645ASQ-105/. Test. AD6645ASV-80. AD6645ASV-105. Parameter. Symbol Temp Level Min. Typ. Max. Min. Unit
AD6645 Data Sheet AD6645ASQ-80/ AD6645ASQ-105/ Test AD6645ASV-80 AD6645ASV-105 Parameter Symbol Temp Level Min Typ Max Min Unit
AD6645 Data Sheet AD6645ASQ-80/ AD6645ASQ-105/ Test AD6645ASV-80 AD6645ASV-105 Parameter Symbol Temp Level Min Typ Max Min Typ Max Unit
DATA-READY (DRY4)/DATA(D13:0), OVR Data-Ready to DATA Delay (Hold Time) tH_DR Full V Note 55 Note 55 50% Duty Cycle Full V 6.6 7.2 7.9 5.1 5.7 6.4 ns Data-Ready to DATA Delay (Setup Time) tS_DR Full V Note 55 Note 55 50% Duty Cycle Full V 2.1 3.6 5.1 0.6 2.1 3.5 ns APERTURE DELAY tA 25°C V −500 −500 ps APERTURE UNCERTAINTY (JITTER) tJ 25°C V 0.1 0.1 ps rms 1 Several timing parameters are a function of tENC and tENCH. 2 Several timing parameters are a function of tENCL and tENCH. 3 ENCODE TO DATA Delay (Hold Time) is the absolute minimum propagation delay through the ADC, tE_RL = tH_E. 4 DRY is an inverted and delayed version of the encode clock. Any change in the duty cycle of the clock will correspondingly change the duty cycle of DRY. 5 Data-ready to DATA Delay (tH_DR and tS_DR) is calculated relative to rated speed grade and is dependent on tENC and duty cycle.
tA N + 3 N AIN N + 1 N + 2 tENCH tENCL N + 4 tENC ENCODE, N N + 1 N + 2 N + 3 N + 4 ENCODE tE_FL tE_RL tE_DR tS_E tH_E D[13:0], OVR N – 3 N – 2 N – 1 N t t H_DR S_DR DRY
002
tDR
02647- Figure 2. Timing Diagram Rev. E | Page 6 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS DIGITAL SPECIFICATIONS AC SPECIFICATIONS SWITCHING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS TERMINOLOGY THEORY OF OPERATION APPLYING THE AD6645 Encoding the AD6645 Driving the Analog Inputs Power Supplies Digital Outputs Grounding LAYOUT INFORMATION JITTER CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
