Datasheet AD9218 (Analog Devices) - 2
Description10-Bit, 40/65/80/105 MSPS 3 V Dual A/D Converter
Pages / Page29 / 2 — AD9218* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
RevisionC
File Format / SizePDF / 887 Kb
AD9218* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
AD9218* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
View a parametric search of comparable parts.
Technical Articles
• Correlating High-Speed ADC Performance to Multicarrier
DOCUMENTATION
3G Requirements
Application Notes
• DNL and Some of its Effects on Converter Performance • AN-282: Fundamentals of Sampled Data Systems • MS-2210: Designing Power Supplies for High Speed ADC • AN-345: Grounding for Low-and-High-Frequency Circuits • Single Chip Realizes Direct-Conversion Rx • AN-501: Aperture Uncertainty and ADC System Performance
DESIGN RESOURCES
• AN-715: A First Approach to IBIS Models: What They Are • AD9218 Material Declaration and How They Are Generated • PCN-PDN Information • AN-737: How ADIsimADC Models an ADC • Quality And Reliability • AN-741: Little Known Characteristics of Phase Noise • Symbols and Footprints • AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter
DISCUSSIONS
• AN-835: Understanding High Speed ADC Testing and View all AD9218 EngineerZone Discussions. Evaluation • AN-905: Visual Analog Converter Evaluation Tool Version
SAMPLE AND BUY
1.0 User Manual • AN-935: Designing an ADC Transformer-Coupled Front Visit the product page to see pricing options. End
Data Sheet TECHNICAL SUPPORT
• AD9218: 10-Bit, 40/65/80/105 MSPS 3 V Dual Analog-to- Submit a technical question or find your regional support Digital Converter Data Sheet number.
TOOLS AND SIMULATIONS DOCUMENT FEEDBACK
• Visual Analog Submit feedback for this data sheet. • AD9218 IBIS Models
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS DIGITAL SPECIFICATIONS AC SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD9218 ENCODE INPUT DIGITAL OUTPUTS ANALOG INPUT VOLTAGE REFERENCE TIMING USER SELECT OPTIONS APPLICATION INFORMATION AD9218/AD9288 CUSTOMER PCB BOM EVALUATION BOARD POWER CONNECTOR ANALOG INPUTS VOLTAGE REFERENCE CLOCKING DATA OUTPUTS DATA FORMAT/GAIN TIMING TROUBLESHOOTING OUTLINE DIMENSIONS ORDERING GUIDE
