Datasheet AD9235 (Analog Devices) - 5
Description12-Bit, 20/40/65 MSPS, 3 V Analog-to-Digital Converter
Pages / Page41 / 5 — AD9235. Data Sheet. DIGITAL SPECIFICATIONS Table 2. Test. …
RevisionD
File Format / SizePDF / 847 Kb
AD9235. Data Sheet. DIGITAL SPECIFICATIONS Table 2. Test. AD9235BRU/BCP-20. AD9235BRU/BCP-40. AD9235BRU/BCP-65. Parameter. Temp. Level. Min
AD9235 Data Sheet DIGITAL SPECIFICATIONS Table 2 Test AD9235BRU/BCP-20 AD9235BRU/BCP-40 AD9235BRU/BCP-65 Parameter Temp Level Min
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5
AD9235 Data Sheet DIGITAL SPECIFICATIONS Table 2. Test AD9235BRU/BCP-20 AD9235BRU/BCP-40 AD9235BRU/BCP-65 Parameter Temp Level Min Typ Max Min Typ Max Min Typ Max Unit
LOGIC INPUTS High Level Input Voltage Full IV 2.0 2.0 2.0 V Low Level Input Voltage Full IV 0.8 0.8 0.8 V High Level Input Current Full IV –10 +10 –10 +10 –10 +10 µA Low Level Input Current Full IV –10 +10 –10 +10 –10 +10 µA Input Capacitance Full V 2 2 2 pF LOGIC OUTPUTS1 DRVDD = 3.3 V High-Level Output Voltage Full IV 3.29 3.29 3.29 V (IOH = 50 µA) High-Level Output Voltage Full IV 3.25 3.25 3.25 V (IOH = 0.5 mA) Low-Level Output Voltage Full IV 0.2 0.2 0.2 V (IOL = 1.6 mA) Low-Level Output Voltage Full IV 0.05 0.05 0.05 V (IOL = 50 µA) DRVDD = 2.5 V High-Level Output Voltage Full IV 2.49 2.49 2.49 V (IOH = 50 µA) High-Level Output Voltage Full IV 2.45 2.45 2.45 V (IOH = 0.5 mA) Low-Level Output Voltage Full IV 0.2 0.2 0.2 V (IOL = 1.6 mA) Low-Level Output Voltage Full IV 0.05 0.05 0.05 V (IOL = 50 µA) 1 Output voltage levels measured with 5 pF load on each output.
SWITCHING SPECIFICATIONS Table 3. Test AD9235BRU/BCP-20 AD9235BRU/BCP-40 AD9235BRU/BCP-65 Parameter Temp Level Min Typ Max Min Typ Max Min Typ Max Unit
CLOCK INPUT PARAMETERS Maximum Conversion Rate Full VI 20 40 65 MSPS Minimum Conversion Rate Full V 1 1 1 MSPS CLK Period Full V 50.0 25.0 15.4 ns CLK Pulse-Width High1 Full V 15.0 8.8 6.2 ns CLK Pulse-Width Low1 Full V 15.0 8.8 6.2 ns DATA OUTPUT PARAMETERS Output Delay2 (tPD) Full V 3.5 3.5 3.5 ns Pipeline Delay (Latency) Full V 7 7 7 Cycles Aperture Delay (tA) Full V 1.0 1.0 1.0 ns Aperture Uncertainty Jitter (tJ) Full V 0.5 0.5 0.5 ps rms Wake-Up Time3 Full V 3.0 3.0 3.0 ms OUT-OF-RANGE RECOVERY TIME Full V 1 1 2 Cycles 1 For the AD9235-65 model only, with duty cycle stabilizer enabled. DCS function not applicable for -20 and -40 models. 2 Output delay is measured from CLK 50% transition to DATA 50% transition, with 5 pF load on each output. 3 Wake-up time is dependent on value of decoupling capacitors; typical values shown with 0.1 µF and 10 µF capacitors on REFT and REFB. Rev. D | Page 4 of 40 Document Outline Specifications DC Specifications Digital Specifications Switching Specifications AC Specifications Absolute Maximum Ratings Explanation of Test Levels ESD Caution Pin Configurations and Function Descriptions Definitions of Specifications Equivalent Circuits Typical Performance Characteristics Applying the AD9235 Theory of Operation Analog Input Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Power Dissipation and Standby Mode Digital Outputs Timing Voltage Reference Internal Reference Connection External Reference Operation Operational Mode Selection TSSOP Evaluation Board LFCSP Evaluation Board Outline Dimensions Ordering Guide
