Datasheet AD9235 (Analog Devices) - 8
Description12-Bit, 20/40/65 MSPS, 3 V Analog-to-Digital Converter
Pages / Page41 / 8 — Data Sheet. AD9235. ABSOLUTE MAXIMUM RATINGS. Table 5. With. Pin Name. …
RevisionD
File Format / SizePDF / 847 Kb
Data Sheet. AD9235. ABSOLUTE MAXIMUM RATINGS. Table 5. With. Pin Name. Respect to. Min. Max. Unit. EXPLANATION OF TEST LEVELS. Test. Levels
Data Sheet AD9235 ABSOLUTE MAXIMUM RATINGS Table 5 With Pin Name Respect to Min Max Unit EXPLANATION OF TEST LEVELS Test Levels
link to page 8
Data Sheet AD9235 ABSOLUTE MAXIMUM RATINGS Table 5. With
Absolute maximum ratings are limiting values to be applied
individually and beyond which the serviceability of the circuit ELECTRICAL may be impaired. Functional operability is not necessarily AVDD AGND –0.3 +3.9 V implied. Exposure to absolute maximum rating conditions for DRVDD DGND –0.3 +3.9 V an extended period of time may affect device reliability. AGND DGND –0.3 +0.3 V
AVDD DRVDD –3.9 +3.9 V
Test
Digital DGND –0.3 DRVDD + 0.3 V
Levels Description
Outputs I 100% production tested. CLK, MODE AGND –0.3 AVDD + 0.3 V II 100% production tested at 25°C and sample tested at VIN+, VIN– AGND –0.3 AVDD + 0.3 V specified temperatures. VREF AGND –0.3 AVDD + 0.3 V III Sample tested only. SENSE AGND –0.3 AVDD + 0.3 V IV Parameter is guaranteed by design and characteriza- REFB, REFT AGND –0.3 AVDD + 0.3 V tion testing. PDWN AGND –0.3 AVDD + 0.3 V V Parameter is a typical value only. ENVIRONMENTAL1 VI 100% production tested at 25°C; guaranteed by de- Operating Temperature –40 +85 °C sign and characterization testing for industrial tem- Junction Temperature 150 °C perature range; 100% production tested at tempera- Lead Temperature (10 sec) 300 °C ture extremes for military devices. Storage Temperature –65 +150 °C 1 Typical thermal impedances (28-lead TSSOP), θJA = 67.7°C/W; (32-lead LFCSP), θJA = 32.5°C/W, θJC = 32.71°C/W. These measurements were taken on a 4-layer board in still air, in accordance with EIA/JESD51-1.
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy elec- trostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. D | Page 7 of 40 Document Outline Specifications DC Specifications Digital Specifications Switching Specifications AC Specifications Absolute Maximum Ratings Explanation of Test Levels ESD Caution Pin Configurations and Function Descriptions Definitions of Specifications Equivalent Circuits Typical Performance Characteristics Applying the AD9235 Theory of Operation Analog Input Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Power Dissipation and Standby Mode Digital Outputs Timing Voltage Reference Internal Reference Connection External Reference Operation Operational Mode Selection TSSOP Evaluation Board LFCSP Evaluation Board Outline Dimensions Ordering Guide
