Datasheet AD10465 (Analog Devices) - 4
DescriptionDual Channel, 14-Bit, 65 MSPS A/D Converter With Analog Input Signal Conditioning
Pages / Page25 / 4 — Data Sheet. AD10465. SPECIFICATIONS. Table 1. Test1. Mil. …
RevisionB
Data Sheet. AD10465. SPECIFICATIONS. Table 1. Test1. Mil. AD10465BZ/QML-H. Parameter. Temp. Level. Subgroup. Min. Typ. Max. Unit
Data Sheet AD10465 SPECIFICATIONS Table 1 Test1 Mil AD10465BZ/QML-H Parameter Temp Level Subgroup Min Typ Max Unit
link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6
AVCC = +5 V; AVEE = –5 V; DVCC = 3.3 V applies to each ADC, unless otherwise noted. Al specifications guaranteed within 100 ms of initial power-up, regardless of sequencing.
Table 1. Test1 Mil AD10465BZ/QML-H Parameter Temp Level Subgroup Min Typ Max Unit
RESOLUTION 14 Bits DC ACCURACY No Missing Codes Full VI 1, 2, 3 Guaranteed Offset Error 25°C I 1 −2.2 ±0.02 +2.2 % FS Full VI 2, 3 −2.2 ±1.0 +2.2 % FS Offset Error Channel Match Full V −1 ±1.0 +1 % Gain Error2 25°C I 1 −3 −1.0 +1 % FS Full VI 2, 3 −5 ±2.0 +5 % FS Gain Error Channel Match 25°C I 1 −1.5 ±0.5 +1.5 % Max I 2 −3 ±1.0 +3 % Min I 3 −5 +5 % ANALOG INPUT (AIN) Input Voltage Range AIN1 Full V ±0.5 V AIN2 Full V ±1.0 V AIN3 Full V ±2 V Input Resistance AIN1 Full IV 12 99 100 101 Ω AIN2 Full IV 12 198 200 202 Ω AIN3 Full IV 12 396 400 404 Ω Input Capacitance3 25°C IV 12 0 4.0 7.0 pF Analog Input Bandwidth4 Full V 100 MHz ENCODE INPUT (ENC, ENC)5 Differential Input Voltage Full IV 0.4 V p-p Differential Input Resistance 25°C V 10 kΩ Differential Input Capacitance 25°C V 2.5 pF SWITCHING PERFORMANCE Maximum Conversion Rate6 Full VI 4, 5, 6 65 MSPS Minimum Conversion Rate6 Full V 12 20 MSPS Aperture Delay (tA) 25°C V 1.5 ns Aperture Delay Matching 25°C IV 12 250 500 ps Aperture Uncertainty (Jitter) 25°C V 0.3 ps rms ENCODE Pulse Width High 25°C IV 12 6.2 7.7 9.2 ns ENCODE Pulse Width Low 25°C IV 12 6.2 7.7 9.2 ns Output Delay (tOD) Full V 6.8 ns ENCODE, Rising to Data Ready, Rising Delay (TE_DR) Full 11.5 ns SNR7 Analog Input @ 4.98 MHz 25°C V 70 dBFS Analog Input @ 9.9 MHz 25°C I 4 69 70 dBFS Full II 5, 6 68 70 dBFS Analog Input @ 19.5 MHz 25°C I 4 68 70 dBFS Full II 5, 6 67 70 dBFS Analog Input @ 32.1 MHz 25°C I 4 67 69 dBFS Full II 5, 6 67 69 dBFS Rev. B | Page 3 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TEST CIRCUITS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND PIN FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION USING THE FLEXIBLE INPUT APPLYING THE AD10465 ENCODING THE AD10465 JITTER CONSIDERATIONS POWER SUPPLIES OUTPUT LOADING LAYOUT INFORMATION EVALUATION BOARD BILL OF MATERIALS LIST FOR AD10465 EVALUATION BOARD SILKSCREENS OUTLINE DIMENSIONS ORDERING GUIDE
