Datasheet AD10465 (Analog Devices) - 10
Description | Dual Channel, 14-Bit, 65 MSPS A/D Converter With Analog Input Signal Conditioning |
Pages / Page | 25 / 10 — Data Sheet. AD10465. TYPICAL PERFORMANCE CHARACTERISTICS. ENCODE = … |
Revision | B |
File Format / Size | PDF / 2.0 Mb |
Data Sheet. AD10465. TYPICAL PERFORMANCE CHARACTERISTICS. ENCODE = 65MSPS. –10. IN = 5MHz (–1dBFS). AIN = 10MHz (–1dBFS). –20
Data Sheet AD10465 TYPICAL PERFORMANCE CHARACTERISTICS 0 0 ENCODE = 65MSPS ENCODE = 65MSPS –10 A –10 IN = 5MHz (–1dBFS) AIN = 10MHz (–1dBFS) –20 SNR = 71.02 –20 SNR = 70.79 SFDR = 92.11dBc SFDR = 86.06dBc –30 –30 –40 –40 –50 –50 –60 –60 B) B) (d –70 (d –70 –80 –80 2 3 –90 2 3 –90 5 4 5 6 6 4 –100 –100 –110 –110 –120
003
–120
006
–130
02356-
–130
02356-
0 2.5 5.0 7.5 10.0 12.5 15.0 17.5 20.0 22.5 25.0 27.5 30.0 32.5 0 2.5 5.0 7.5 10.0 12.5 15.0 17.5 20.0 22.5 25.0 27.5 30.0 32.5 FREQUENCY (MHz) FREQUENCY (MHz)
Figure 8. Single Tone @ 5 MHz Figure 11. Single Tone @ 10 MHz
0 0 ENCODE = 65MSPS ENCODE = 65MSPS –10 A –10 IN = 20MHz (–1dBFS) AIN = 25MHz (–1dBFS) –20 SNR = 70.71 –20 SNR = 70.36 SFDR = 79.73dBc SFDR = 74.58dBc –30 –30 –40 –40 –50 –50 –60 –60 B) B) (d –70 (d –70 3 3 2 –80 –80 2 –90 5 –90 5 4 6 4 6 –100 –100 –110 –110 –120
004
–120
007
–130
02356-
–130
02356-
Figure 9. Single Tone @ 20 MHz Figure 12. Single Tone @ 25 MHz
0 100 ENCODE = 65MSPS –10 AIN = 32MHz (–1dBFS) 90 –20 SNR = 70.22 SFDR SFDR = 66.40dBc 80 –30 –40 70 –50 SINAD 60 –60 B) 2 Bc) 3 50 (d –70 (–d 40 –80 –90 5 30 6 –100 4 20 –110 10
008
–120
005
–130
02356-
0
02356-
0 2.5 5.0 7.5 10.0 12.5 15.0 17.5 20.0 22.5 25.0 27.5 30.0 32.5 4.9898 9.989 19.000 32.000 FREQUENCY (MHz) INPUT FREQUENCY (MHz)
Figure 10. Single Tone @ 32 MHz Figure 13. SFDR and SINAD vs. Frequency Rev. B | Page 9 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TEST CIRCUITS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND PIN FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION USING THE FLEXIBLE INPUT APPLYING THE AD10465 ENCODING THE AD10465 JITTER CONSIDERATIONS POWER SUPPLIES OUTPUT LOADING LAYOUT INFORMATION EVALUATION BOARD BILL OF MATERIALS LIST FOR AD10465 EVALUATION BOARD SILKSCREENS OUTLINE DIMENSIONS ORDERING GUIDE
