Data SheetAD10465ABSOLUTE MAXIMUM RATINGSTable 2. Stresses at or above those listed under Absolute Maximum ParameterMin MaxUnits Ratings may cause permanent damage to the product. This is a ELECTRICAL stress rating only; functional operation of the product at these VCC Voltage 0 +7 V or any other conditions above those indicated in the operational VEE Voltage –7 0 V section of this specification is not implied. Operation beyond Analog Input Voltage VEE VCC V the maximum operating conditions for extended periods may Analog Input Current −10 +10 mA affect product reliability. Digital Input Voltage (ENCODE) 0 VCC V Table 3. Test Levels ENCODE, ENCODE Differential Voltage 4 V Level Description Digital Output Current −10 +10 mA I 100% production tested. ENVIRONMENTAL1 II 100% production tested at 25°C, and sample tested at Operating Temperature Range (Case) −40 +85 °C specified temperatures. AC testing done on sample Maximum Junction Temperature 174 °C basis. Lead Temperature (Soldering, 10 sec) 300 °C III Sample tested only. Storage Temperature Range (Ambient) −65 +150 °C IV Parameter is guaranteed by design and characterization testing. 1 Typical thermal impedance for 68-lead CLCC package: θJC = 2.2°C/W; θJA = 24.3°C/W. V Parameter is a typical value only. VI 100% production tested at 25°C, sample tested at temperature extremes. ESD CAUTION Rev. B | Page 7 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TEST CIRCUITS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND PIN FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION USING THE FLEXIBLE INPUT APPLYING THE AD10465 ENCODING THE AD10465 JITTER CONSIDERATIONS POWER SUPPLIES OUTPUT LOADING LAYOUT INFORMATION EVALUATION BOARD BILL OF MATERIALS LIST FOR AD10465 EVALUATION BOARD SILKSCREENS OUTLINE DIMENSIONS ORDERING GUIDE
