Datasheet AD9410 (Analog Devices) - 4
Description10-Bit, 210 MSPS ADC
Pages / Page21 / 4 — AD9410. SPECIFICATIONS DC SPECIFICATIONS. Table 1. Parameter. Temp. Test …
File Format / SizePDF / 389 Kb
AD9410. SPECIFICATIONS DC SPECIFICATIONS. Table 1. Parameter. Temp. Test Level. Min. Typ. Max. Unit
AD9410 SPECIFICATIONS DC SPECIFICATIONS Table 1 Parameter Temp Test Level Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4
VDD = 3.3 V, VD = 3.3 V, VCC = 5.0 V; 2.5 V external reference; AIN = −0.5 dBFS; clock input = 210 MSPS; TA = 25°C; unless otherwise noted.
Table 1. Parameter Temp Test Level Min Typ Max Unit
RESOLUTION 10 Bits DC ACCURACY No Missing Codes Full IV Guaranteed Differential Nonlinearity 25°C I −1.0 ±0.5 +1.25 LSB Full VI −1.0 +1.5 LSB Integral Nonlinearity 25°C I −2.5 ±1.65 +2.5 LSB Full VI −3.0 +3.0 LSB Gain Error 25°C I −6.0 0 +6.0 % FS Gain Temperature Coefficient Full V 130 ppm/°C ANALOG INPUT Input Voltage Range (With Respect to AIN) Full V ±768 mV p-p Common-Mode Voltage Full V 3.0 V Input Offset Voltage 25°C I −15 +3 +15 mV Full VI −20 +20 mV Reference Voltage Full VI 2.4 2.5 2.6 V Reference Temperature Coefficient Full V 50 ppm/°C Input Resistance Full VI 610 875 1250 Ω Input Capacitance 25°C V 3 pF Analog Bandwidth, Full Power 25°C V 500 MHz POWER SUPPLY Power Dissipation AC1 25°C V 2.1 W Power Dissipation DC2 Full VI 2.0 2.4 W I 2 VCC Full VI 128 145 mA I 2 VD Full VI 401 480 mA Power Supply Rejection Ratio, PSRR 25°C I −7.5 +0.5 +7.5 mV/V 1 Clock input = 210 MSPS, AIN = –0.5 dBFS, 10 MHz sine wave, IVDD = 31 mA typical at CLOAD = 5 pF. 2 Clock input = 210 MSPS, AIN = dc, outputs not switching. Rev. A | Page 3 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS SWITCHING SPECIFICATIONS DIGITAL SPECIFICATIONS AC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS EXPLAINATION OF TEST LEVELS Test Level ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD9410 Clock Input ANALOG INPUT DIGITAL OUTPUTS CLOCK OUTPUTS (DCO, ) VOLTAGE REFERENCE TIMING DATA SYNC (DS) OUTLINE DIMENSIONS ORDERING GUIDE
