Datasheet AD7898 (Analog Devices) - 3
Description5V, 12-Bit, Serial 220 kSPS ADC in a 8-Lead Package
Pages / Page17 / 3 — AD7898–SPECIFICATIONS1 (VDD = 4.75 V to 5.25 V, VDRIVE = 2.7 V to 5.25 V; …
RevisionA
File Format / SizePDF / 243 Kb
AD7898–SPECIFICATIONS1 (VDD = 4.75 V to 5.25 V, VDRIVE = 2.7 V to 5.25 V; REF IN = 2.5 V. Specifications apply
AD7898–SPECIFICATIONS1 (VDD = 4.75 V to 5.25 V, VDRIVE = 2.7 V to 5.25 V; REF IN = 2.5 V Specifications apply
AD7898–SPECIFICATIONS1 (VDD = 4.75 V to 5.25 V, VDRIVE = 2.7 V to 5.25 V; REF IN = 2.5 V. Specifications apply to both Mode 0 and Mode 1 operations; TA = TMIN to TMAX, unless otherwise noted.) Parameter A Versionl Unit Test Conditions/Comments
DYNAMIC PERFORMANCE Signal to (Noise + Distortion) Ratio2 TMIN to TMAX 71 dB min fIN = 30 kHz Sine Wave Total Harmonic Distortion (THD)2 –78 dB max fIN = 30 kHz Sine Wave Peak Harmonic or Spurious Noise2 –89 dB typ fIN = 30 kHz Sine Wave Intermodulation Distortion (IMD)2 fa = 29.1 kHz, fb = 29.9 kHz 2nd Order Terms –88 dB typ 3rd Order Terms –88 dB typ Aperture Delay 20 ns typ Aperture Jitter 75 ps typ Full Power Bandwidth–AD7898-10 3.6 MHz typ @ 3 dB Full Power Bandwidth–AD7898-3 4.7 MHz typ @ 3 dB Full Power Bandwidth–AD7898-10 2.15 MHz typ @ 1 dB Full Power Bandwidth–AD7898-3 2.4 MHz typ @ 1 dB DC ACCURACY Resolution 12 Bits Minimum Resolution for Which 12 Bits No Missing Codes are Guaranteed Relative Accuracy2 ±1 LSB max Differential Nonlinearity2 ±0.9 LSB max Positive Full-Scale Error2 ±3 LSB max Negative Full-Scale Error2 ±3 LSB max Bipolar Zero Error ±4 LSB max ANALOG INPUT AD7898-10 Input Voltage Range ±10 Volts Input Resistance 24 kΩ min AD7898-3 Input Voltage Range ±2.5 Volts Input Resistance 5 kΩ min REFERENCE INPUT REF IN Input Voltage Range 2.375/2.625 V min/V max 2.5 V ± 5% Input Current 1 µA max Input Capacitance2, 3 10 pF max LOGIC INPUTS Input High Voltage, VINH VDRIVE × 0.7 V min Input Low Voltage, V 4 INL VDRIVE × 0.3 V max Input Current, I ± IN 1 µA max Typically 10 nA, VIN = 0 V or VDRIVE Input Capacitance, C 2, 3 IN 10 pF max LOGIC OUTPUTS Output High Voltage, VOH VDRIVE – 0.4 V min ISOURCE = 200 µA; VDRIVE = 2.7 V to 5.25 V Output Low Voltage, VOL 0.4 V max ISINK = 200 µA Floating-State Leakage Current ±10 µA max Floating-State Output Capacitance2, 3 10 pF max Output Coding Twos Complement CONVERSION RATE Mode 0 Operation 220 kSPS max With VDRIVE = 5 V ± 5% 215 kSPS max With VDRIVE = 2.7 V to 3.6 V Mode 1 Operation 220 kSPS max POWER REQUIREMENTS VDD 4.75 to 5.25 V min to V max For Specified Performance VDRIVE 2.7 to 5.25 V min to V max For Specified Performance IDD Static 4.25 mA max Digital Inputs @ VDRIVE IDD Operational 4.5 mA max Digital Inputs @ VDRIVE Power Dissipation 22.5 mW max POWER-DOWN MODE IDD @ 25°C 5 µA max Digital Inputs @ GND, VDD = 5 V ± 5% TMIN to TMAX 20 µA max Digital Inputs @ GND, VDD = 5 V ± 5% Power Dissipation @ 25°C (Operational) 25 µW max VDD = 5 V NOTES 1Temperature ranges are as follows: A Version: –40°C to +85°C. 2See Terminology. 3Sample tested @ 25°C to ensure compliance. 4Operational with VDRIVE = 2.35 V, with Input Low Voltage, VINL = 0.4 V Specifications subject to change without notice. –2– REV. A Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS TERMINOLOGY Signal to (Noise + Distortion) Ratio Total Harmonic Distortion Peak Harmonic or Spurious Noise Intermodulation Distortion Relative Accuracy Differential Nonlinearity Positive Full-Scale Error (AD7898-10) Positive Full-Scale Error (AD7898-3) Bipolar Zero Error (AD7898-10, AD7898-3) Negative Full-Scale Error (AD7898-10) Negative Full-Scale Error (AD7898-3) Track/Hold Acquisition Time PSR (Power Supply Rejection) PERFORMANCE CURVES Noise CONVERTER DETAILS CIRCUIT DESCRIPTION Analog Input Section Acquisition Time TYPICAL CONNECTION DIAGRAM VDRIVE Feature Track/Hold Section Reference Input SERIAL INTERFACE OPERATING MODES Mode 0 Operation Mode 1 Operation Mode Selection Power-Down Mode Power-Up Times MICROPROCESSOR/MICROCONTROLLER INTERFACE FOR MODE 0 OPERATION 8x51/L51 to AD7898 Interface 68HC11/L11 to AD7898 Interface ADSP-2103/ADSP-2105 to AD7898 Interface DSP56002/L002 to AD7898 Interface MICROPROCESSOR INTERFACING FOR MODE 1 TMS320C5x/C54x to AD7898 Interface AD7898 to ADSP-21xx Interface AD7898 to DSP56xxx Interface AD7898 to MC68HC16 Interface OUTLINE DIMENSIONS Revision History
