Datasheet AD7892 (Analog Devices) - 7
DescriptionTrue Bipolar Input, Single Supply, Parallel, 12-Bit 600 kSPS ADC
Pages / Page15 / 7 — AD7892. PIN FUNCTION DESCRIPTION. Pin No. Mnemonic. Description
RevisionC
File Format / SizePDF / 177 Kb
AD7892 PIN FUNCTION DESCRIPTION Pin No Mnemonic Description
AD7892 PIN FUNCTION DESCRIPTION Pin No. Mnemonic Description
1 VDD Positive Supply Voltage, +5 V ± 5%. 2 STANDBY Standby Input. Logic Input. With this input at a logic high, the part is in its normal operating mode; with this input at a logic low, the part is placed in its standby or power-down mode, which reduces power consumption to 5 mW typical. 3 VIN2 Analog Input 2. For the AD7892-1, this input either connects to AGND or to VIN1 to determine the analog input voltage range. With VIN2 connected to AGND on the AD7892-1, the analog input range at the VIN1 input is ± 10 V. With VIN2 connected to VIN1 on the AD7892-1, the analog input range to the part is ± 5 V. For the AD7892-2 and AD7892-3, this input can be left unconnected but must not be connected to a potential other than AGND. 4 VIN1 Analog Input 1. The analog input voltage to be converted by the AD7892 is applied to this input. For the AD7892-1, the input voltage range is either ± 5 V or ± 10 V depending on where the VIN2 input is connected. For the AD7892-2, the voltage range on the VIN1 input is 0 V to +2.5 V with respect to the voltage appearing at the VIN2 input. For the AD7892-3, the voltage range on the VIN1 input is ± 2.5 V. 5 REF OUT/REF IN Voltage Reference Output/Input. The part can be used with either its own internal reference or with an external reference source. The on-chip +2.5 V reference is provided at this pin. When using this internal reference as the reference source for the part, REF OUT should be decoupled to AGND with a 0.1 µF disc ceramic capacitor. The output impedance of this reference source is typically 5.5 kΩ. When using an external reference source as the reference voltage for the part, the reference source should be connected to this pin. This overdrives the internal reference and provides the reference source for the part. The REF IN input is buffered on-chip but must be able to sink or source current through the resistor to the output of the on-chip reference. The nominal reference voltage for correct operation of the AD7892 is +2.5 V. 6 AGND Analog Ground. Ground reference for track/hold, comparator and DAC. 7 MODE Mode. Control input which determines the interface mode for the AD7892. With this pin at a logic low, the device is in its serial interface mode; with this pin at a logic high, the device is in its parallel interface mode. 8 DB11/LOW Data Bit 11/Test Pin. When the device is in its parallel mode, this pin is Data Bit 11 (MSB), a three-state TTL-compatible output. When the device is in its serial mode, this is used as a test pin which must be tied to a logic low for correct operation of the AD7892. 9 DB10/LOW Data Bit 10/Test Pin. When the device is in its parallel mode, this pin is Data Bit 10, a three-state TTL-compatible output. When the device is in its serial mode, this is used as a test pin which must be tied to a logic low for correct operation of the AD7892. 10 DB9 Data Bit 9. Three-state TTL-compatible output. This output should be left unconnected when the device is in its serial mode. 11 DB8 Data Bit 8. Three-state TTL-compatible output. This output should be left unconnected when the device is in its serial mode. 12 DB7 Data Bit 7. Three-state TTL-compatible output. This output should be left unconnected when the device is in its serial mode. 13 DB6 Data Bit 6. Three-state TTL-compatible output. This output should be left unconnected when the device is in its serial mode. 14 DGND Digital Ground. Ground reference for digital circuitry. 15 DB5/SDATA Data Bit 5/Serial Data. When the device is in its parallel mode, this pin is Data Bit 5, a three-state TTL-compatible output. When the device is in its serial mode, this becomes the serial data output line. Sixteen bits of serial data are provided with four leading zeros preceding the 12 bits of valid data. Serial data is valid on the falling edge of SCLK for sixteen edges after RFS goes low. Output coding is two’s complement for AD7892-1 and AD7892-3 and straight (natural) binary for AD7892-2. –6– REV. C
