Datasheet AD7893 (Analog Devices) - 6
DescriptionTrue Bipolar Input, Single Supply, 12-Bit, Serial 6 µs ADC in 8-Pin Package
Pages / Page13 / 6 — AD7893. TERMINOLOGY. Relative Accuracy. Signal to (Noise + Distortion) …
RevisionE
File Format / SizePDF / 379 Kb
AD7893. TERMINOLOGY. Relative Accuracy. Signal to (Noise + Distortion) Ratio. Differential Nonlinearity
AD7893 TERMINOLOGY Relative Accuracy Signal to (Noise + Distortion) Ratio Differential Nonlinearity
Relative accuracy or endpoint nonlinearity is the maximum This is the measured ratio of signal to (noise + distortion) at the deviation from a straight line passing through the endpoints of output of the A/D converter. The signal is the rms amplitude of the ADC transfer function. the fundamental. Noise is the rms sum of all nonfundamental
signals up to half the sampling frequency (fS/2), excluding dc. This is the difference between the measured and the ideal 1 LSB The ratio is dependent upon the number of quantization levels change between any two adjacent codes in the ADC. in the digitization process; the more levels, the smaller the quan-
Positive Full-Scale Error (AD7893-10)
tization noise. The theoretical signal to (noise + distortion) ratio This is the deviation of the last code transition (01 . 110 to for an ideal N-bit converter with a sine wave input is given by: 01 . 111) from the ideal 4 × REF IN – 1 LSB (AD7893-10 Signal to (Noise + Distortion) = (6.02 N + 1.76) dB ±10 V range) after the Bipolar Zero Error has been adjusted out. Thus for a 12-bit converter, this is 74 dB.
Positive Full-Scale Error (AD7893-3) Total Harmonic Distortion
This is the deviation of the last code transition (01 . 110 to Total harmonic distortion (THD) is the ratio of the rms sum of 01 . 111) from the ideal (REF IN – 1 LSB) after the harmonics to the fundamental. For the AD7893, it is defined as: Bipolar Zero Error has been adjusted out.
Positive Full-Scale Error (AD7893-5)
V 2 2 2 2 2 This is the deviation of the last code transition (11 . 110 to +V +V +V +V THD(dB ) = 20 log 2 3 4 5 6 11 . 111) from the ideal (2 × REF IN – 1 LSB) after the Uni- V 1 polar Offset Error has been adjusted out. where V1 is the rms amplitude of the fundamental and V2, V3,
Positive Full-Scale Error (AD7893-2)
V4, V5 and V6 are the rms amplitudes of the second through the This is the deviation of the last code transition (11 . 110 to sixth harmonics. 11 . 111) from the ideal (REF IN – 1 LSB) after the Unipolar
Peak Harmonic or Spurious Noise
Offset Error has been adjusted out. Peak harmonic or spurious noise is defined as the ratio of the
Bipolar Zero Error (AD7893-10,
6
10 V; AD7893-3,
6
2.5 V)
rms value of the next largest component in the ADC output This is the deviation of the midscale transition (all 0s to all 1s) spectrum (up to fS/2 and excluding dc) to the rms value of the from the ideal 0 V (AGND). fundamental. Normally, the value of this specification is deter-
Unipolar Offset Error (AD7893-2, AD7893-5)
mined by the largest harmonic in the spectrum, but for parts This is the deviation of the first code transition (00 . 000 to where the harmonics are buried in the noise floor, it will be a 00 . 001) from the ideal 1 LSB. noise peak.
Negative Full-Scale Error (AD7893-10) Intermodulation Distortion
This is the deviation of the first code transition (10 . 000 to With inputs consisting of sine waves at two frequencies, fa and 10 . 001) from the ideal –4 × REF IN + 1 LSB (AD7893-10 fb, any active device with nonlinearities will create distortion ± 10 V range) after Bipolar Zero Error has been adjusted out. products at sum and difference frequencies of mfa ± nfb where m, n = 0, 1, 2, 3, etc. Intermodulation terms are those for
Negative Full-Scale Error (AD7893-3)
which neither m nor n are equal to zero. For example, the second This is the deviation of the first code transition (10 . 000 to order terms include (fa + fb) and (fa – fb), while the third order 10 . 001) from the ideal (–REF IN + 1 LSB) after Bipolar terms include (2 fa + fb), (2 fa – fb), (fa + 2 fb) and (fa – 2 fb). Zero Error has been adjusted out. The AD7893 is tested using the CCIF standard where two
Track/Hold Acquisition Time
input frequencies near the top end of the input bandwidth are Track/Hold acquisition time is the time required for the output used. In this case, the second and third order terms are of differ- of the track/hold amplifier to reach its final value, within ent significance. The second order terms are usually distanced ±1/2 LSB, after the end of conversion (the point at which the in frequency from the original sine waves, while the third order track/hold returns to track mode). It also applies to situations terms are usually at a frequency close to the input frequencies. where there is a step input change on the input voltage applied As a result, the second and third order terms are specified sepa- to the VIN input of the AD7893. This means that the user must rately. The calculation of the intermodulation distortion is per wait for the duration of the track/hold acquisition time after the the THD specification where it is the ratio of the rms sum of the end of conversion or after a step input change to VIN before individual distortion products to the rms amplitude of the fun- starting another conversion, to ensure that the part operates to damental expressed in dBs. specification. REV. E –5–
