Datasheet AD7880 (Analog Devices) - 6
DescriptionCMOS, Single +5 V Supply, Low Power, 12-Bit Sampling ADC
Pages / Page17 / 6 — AD7880. CIRCUIT INFORMATION. VINA. VINB. VDAC. CONVERTER DETAILS. Table …
File Format / SizePDF / 375 Kb
AD7880. CIRCUIT INFORMATION. VINA. VINB. VDAC. CONVERTER DETAILS. Table II. Analog Input Ranges. Analog Input. Input Connections
AD7880 CIRCUIT INFORMATION VINA VINB VDAC CONVERTER DETAILS Table II Analog Input Ranges Analog Input Input Connections
AD7880 CIRCUIT INFORMATION R
The AD7880 is a +5 V single supply 12-bit A/D converter. The
VINA
part requires no external components apart from a 2.5 MHz ex-
ternal clock and power supply decoupling capacitors. It contains
R
a 12-bit successive approximation ADC based on a fast-settling
VINB
voltage-output DAC, a high speed comparator and SAR, as well
as the necessary control logic. The charge balancing comparator used in the AD7880 provides the user with an inherent track-
VDAC
and-hold function. The ADC is specified to work with sampling rates up to 66 kHz. Figure 4. AD7880 Input Circuit
CONVERTER DETAILS
The AD7880 accommodates three separate input ranges, 0 to The AD7880 conversion cycle is initiated on the rising edge of VREF, 0 to 2 VREF and ± VREF. The input configurations corre- the CONVST pulse, as shown in the timing diagram of Figure sponding to these ranges are shown in Figures 5, 6 and 7. 1. The rising edge of the CONVST pulse places the track/hold With VREF = VDD and using a nominal VDD of +5 V, the input amplifier into “HOLD” mode. The conversion cycle then takes ranges are 0 V to 5 V, 0 V to 10 V and +5 V, as shown in between 26 and 28 clock periods. The maximum specified con- Table II. version time is 12 µs. This corresponds to a conversion cycle time of 28 clock periods with a CLKIN frequency of 2.5 MHz
and also includes internal propagation delays. During conver-
Analog Input Input Connections Connection
sion the BUSY output will remain low, and the output databus
Range VREF VINA VINB Diagram
drivers will be three-stated. When a conversion is completed, the BUSY output will go to a high level, and the result of the 0 V to +5 V VDD VIN VIN Figure 5 conversion can be read by bringing CS and RD low. 0 V to +10 V VDD VIN AGND Figure 6 The track/hold amplifier acquires a 12-bit input signal in 3 µs. ±5 V VDD VIN VREF Figure 7 The overall throughput time for the AD7880 is equal to the conversion time plus the track/hold acquisition time. For a 2.5 MHz input clock the throughput time is 15 µs.
SAMPLING R COMPARATOR V = 0 TO V IN REF V 0 TO VREF INA REFERENCE INPUT + R
For specified performance, it is recommended that the reference
VINB
input be tied to VDD. The part, however, will operate with a ref- erence down to 2.5 V though with reduced performance specifi-
VREF VREF 12-BIT DAC
cations. Figure 3 shows a graph of signal-to-noise ratio (SNR)
AGND
versus VREF. VREF must not be allowed to go above VDD by more than 100 mV. Figure 5. 0 to VREF Unipolar Input Configuration
74 F = 51.2kHz SAMPLING S 72 R COMPARATOR F = 2.525kHz IN V = 0 TO 2V IN REF V 0 TO VREF T = 25 C INA A + R 70 VINB 68 VREF – dBs VREF 12-BIT DAC 66 AGND SNR 64
Figure 6. 0 to 2 VREF Unipolar Input Configuration
62 SAMPLING R 60 COMPARATOR 2 3 4 5 V = V ± IN REF V 0 TO VREF V – Volts INA + REF R
Figure 3. SNR vs. V
V
REF
INB VREF VREF 12-BIT DAC ANALOG INPUT AGND
The AD7880 has two analog input pins, VINA and VINB. Figure 4 shows the input circuitry to the ADC sampling comparator. The on-board attenuator network, made up of equal resistors, allows for various input ranges. Figure 7. ±VREF Bipolar Input Configuration REV. 0 –5–
