Datasheet AD5380 (Analog Devices) - 9
Description40-Channel, 3 V/5 V, Single-Supply, 14-Bit, denseDAC
Pages / Page41 / 9 — AD5380. Data Sheet. Parameter. AD5380-31. Unit. Test Conditions/Comments. …
RevisionD
File Format / SizePDF / 929 Kb
AD5380. Data Sheet. Parameter. AD5380-31. Unit. Test Conditions/Comments. AC CHARACTERISTICS1. Table 3. Parameter. All
AD5380 Data Sheet Parameter AD5380-31 Unit Test Conditions/Comments AC CHARACTERISTICS1 Table 3 Parameter All
link to page 9 link to page 9 link to page 9 link to page 9 link to page 19 link to page 9 link to page 9 link to page 9
LOGIC OUTPUTS (BUSY, SDO)3 VOL, Output Low Voltage 0.4 V max Sinking 200 µA VOH, Output High Voltage DVDD – 0.5 V min Sourcing 200 µA High Impedance Leakage Current ±1 µA max SDO only High Impedance Output Capacitance 5 pF typ SDO only LOGIC OUTPUT (SDA)3 VOL, Output Low Voltage 0.4 V max ISINK = 3 mA 0.6 V max ISINK = 6 mA Three-State Leakage Current ±1 µA max Three-State Output Capacitance 8 pF typ POWER REQUIREMENTS AVDD 2.7/3.6 V min/max DVDD 2.7/5.5 V min/max Power Supply Sensitivity3 ∆Midscale/∆ΑVDD –85 dB typ AIDD 0.375 mA/channel max Outputs unloaded; boost off; 0.25 mA/channel typical 0.475 mA/channel max Outputs unloaded; boost on; 0.325 mA/channel typical DIDD 1 mA max VIH = DVDD, VIL = DGND AIDD (Power-Down) 20 µA max Typically 100 nA DIDD (Power-Down) 20 µA max Typically 1 µA Power Dissipation 48 mW max Outputs unloaded; boost off, AVDD = DVDD = 3 V 1 AD5380-3 is calibrated using an external 1.25 V reference. Temperature range is –40°C to +85°C. 2 Accuracy guaranteed from VOUT = 10 mV to AVDD – 50 mV. 3 Guaranteed by characterization, not production tested. 4 Default on the AD5380-3 is 1.25 V. Programmable to 2.5 V via CR12 in the AD5380 control register; operating the AD5380-3 with a 2.5 V reference wil lead to degraded accuracy specifications and limited input code range.
AC CHARACTERISTICS1
AVDD = 2.7 V to 3.6 V or 4.5 V to 5.5 V; DVDD = 2.7 V to 5.5 V; AGND = DGND = 0 V.
Table 3. Parameter All Unit Test Conditions/Comments
DYNAMIC PERFORMANCE Output Voltage Settling Time2 1/4 scale to 3/4 scale change settling to ±1 LSB 3 µs typ Boost mode off, CR11 = 0 8 µs max Boost mode off, CR11 = 0 Slew Rate2 1.5 V/µs typ Boost mode off, CR11 = 0 2.5 V/µs typ Boost mode on, CR11 = 1 Digital-to-Analog Glitch Energy 12 nV-s typ Glitch Impulse Peak Amplitude 15 mV typ DAC-to-DAC Crosstalk 1 nV-s typ See Terminology section Digital Crosstalk 0.8 nV-s typ Digital Feedthrough 0.1 nV-s typ Effect of input bus activity on DAC output under test Output Noise 0.1 Hz to 10 Hz 15 µV p-p typ External reference, midscale loaded to DAC 40 µV p-p typ Internal reference, midscale loaded to DAC Output Noise Spectral Density At 1 kHz 150 nV/√Hz typ At 10 kHz 100 nV/√Hz typ 1 Guaranteed by design and characterization, not production tested. 2 The slew rate can be programmed via the current boost control bit (CR11) in the AD5380 control register. Rev. D | Page 8 of 40 Document Outline Features Integrated Functions Applications Functional Block Diagram Table Of Contents Revision History General Description Specifications AD5380-5 Specifications AD5380-3 Specifications AC Characteristics Timing Characteristics Serial Interface I2C Serial Interface Parallel Interface Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Terminology Typical Performance Characteristics Functional Description DAC Architecture—General Data Decoding On-Chip Special Function Registers (SFR) SFR Commands NOP (No Operation) Write CLR Code Soft CLR Soft Power-Down Soft Power-Up Soft RESET Control Register Write/Read Control Register Contents Channel Monitor Function Hardware Functions RESET\ Function Asynchronous Clear Function BUSY\ and LDAC\ Functions FIFO Operation in Parallel Mode Power-On Reset Power-Down AD5380 Interfaces DSP-, SPI-, Microwire-Compatible Serial Interfaces Standalone Mode Daisy-Chain Mode Readback Mode I2C Serial Interface I2C Data Transfer START and STOP Conditions Repeated START Conditions Acknowledge Bit (ACK) AD5380 Slave Addresses Write Operation 4-Byte Mode 3-Byte Mode 2-Byte Mode Parallel Interface CS\ Pin WR\ Pin REG0, REG1 Pins Pins A5 to A0 Pins DB13 to DB0 Microprocessor Interfacing Parallel Interface AD5380 to MC68HC11 AD5380 to PIC16C6x/7x AD5380 to 8051 AD5380 to ADSP-BF527 Applications Information Power Supply Decoupling Power Supply Sequencing Typical Configuration Circuit AD5380 Monitor Function Toggle Mode Function Thermal Monitor Function AD5380 in a MEMS Based Optical Switch Optical Attenuators Utilizing the AD5380 FIFO Outline Dimensions Ordering Guide
