Datasheet DAC8412, DAC8413 (Analog Devices) - 3
DescriptionQuad, 12-Bit DAC Voltage Output with Readback
Pages / Page20 / 3 — Data Sheet. DAC8412/DAC8413. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. …
RevisionG
File Format / SizePDF / 484 Kb
Data Sheet. DAC8412/DAC8413. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
Data Sheet DAC8412/DAC8413 SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 Parameter Symbol Conditions Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
VDD = +15.0 V, VSS = −15.0 V, VLOGIC = +5.0 V, VREFH = +10.0 V, VREFL = −10.0 V,−40°C ≤ TA ≤ +85°C, unless otherwise noted.1
Table 1. Parameter Symbol Conditions Min Typ Max Unit
ACCURACY Integral Nonlinearity Error INL E grade ±0.25 ±0.5 LSB F grade ±1 LSB Differential Nonlinearity Error DNL Monotonic over temperature −1 LSB Min-Scale Error VZSE RL = 2 kΩ ±2 LSB Full-Scale Error VFSE RL = 2 kΩ ±2 LSB Min-Scale Temperature Coefficient TCVZSE RL = 2 kΩ 15 ppm/°C Full-Scale Temperature Coefficient TCVFSE RL = 2 kΩ 20 ppm/°C Linearity Matching Adjacent DAC Matching ±1 LSB REFERENCE Positive Reference Input Voltage Range2 VREFL + 2.5 VDD − 2.5 V Negative Reference Input Voltage Range2 −10 VREFH − 2.5 V Reference High Input Current IREFH −2.75 +1.5 +2.75 mA Reference Low Input Current IREFL −2.75 −2 0 mA Large Signal Bandwidth BW −3 dB, VREFH = 0 V to 10 V p-p 160 kHz AMPLIFIER CHARACTERISTICS Output Current IOUT RL = 2 kΩ, CL = 100 pF –5 +5 mA Settling Time tS To 0.01%, 10 V step, RL = 1 kΩ 10 μs Slew Rate SR 10% to 90% 2.2 V/μs Analog Crosstalk 72 dB LOGIC CHARACTERISTICS Logic Input High Voltage VINH TA = 25°C 2.4 V Logic Input Low Voltage VINL TA = 25°C 0.8 V Logic Output High Voltage VOH IOH = 0.4 mA 2.4 V Logic Output Low Voltage VOL IOL = −1.6 mA 0.4 V Logic Input Current IIN 1 μA Input Capacitance CIN 8 pF Digital Feedthrough3 VREFH = 2.5 V, VREFL = 0 V 5 nV-sec LOGIC TIMING CHARACTERISTICS3, 4 Chip Select Write Pulse Width tWCS 80 ns Write Setup tWS tWCS = 80 ns 0 ns Write Hold tWH tWCS = 80 ns 0 ns Address Setup tAS 0 ns Address Hold tAH 0 ns Load Setup tLS 70 ns Load Hold tLH 30 ns Write Data Setup tWDS tWCS = 80 ns 20 ns Write Data Hold tWDH tWCS = 80 ns 0 ns Load Data Pulse Width tLDW 170 ns Reset Pulse Width tRESET 140 ns Chip Select Read Pulse Width tRCS 130 ns Read Data Hold tRDH tRCS = 130 ns 0 ns Read Data Setup tRDS tRCS = 130 ns 0 ns Data to High-Z tDZ CL = 10 pF 200 ns Chip Select to Data tCSD CL = 100 pF 160 ns Rev. G | Page 3 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Introduction DACs Glitch Reference Inputs Digital I/O Coding Supplies Amplifiers Reference Configurations Single +5 V Supply Operation Outline Dimensions Ordering Guide
