Datasheet AD558 (Analog Devices) - 9
DescriptionDACPORT Low Cost, Complete µP-Compatible 8-Bit DAC
Pages / Page10 / 9 — OUTLINE DIMENSIONS. AD558. 0.775. 0.755. 0.735. 0.280. 0.250. PIN 1. …
OUTLINE DIMENSIONS. AD558. 0.775. 0.755. 0.735. 0.280. 0.250. PIN 1. INDICATOR. 0.240. TOP VIEW. 0.100. 0.325. BSC. 0.195. 0.310. 0.130. 0.210. 0.300. MAX
OUTLINE DIMENSIONS AD558 0.775 0.755 0.735 0.280 0.250 PIN 1 INDICATOR 0.240 TOP VIEW 0.100 0.325 BSC 0.195 0.310 0.130 0.210 0.300 MAX
OUTLINE DIMENSIONS AD558 0.775 0.755 mA 0.735 16 16 9 0.280 0.250 PIN 1 1 INDICATOR 0.240 8 14 I TOP VIEW CC 0.100 0.325 BSC 0.195 0.310 12 0.130 0.210 0.300 MAX SIDE VIEW 0.115 0.015 0.150 MIN 0.015 10 0.130 GAUGE END VIEW 0.115 PLANE 0.012 SEATING 0.010 PLANE 0.022 0.021 0.008 0.430 0.018 0.070 0.016 MAX 0.015 0.045 0.060 0.011 0.039 0.055 0.030 COMPLIANT TO JEDEC STANDARDS MS-001-BB 4 6 8 10 12 14 16 18 03-07-2014-D VOLTS 16-Lead Plastic Dual In-Line Package [PDIP] VCC Narrow Body (N-16)
Figure 15. Quiescent Current vs. Power Supply
Dimensions shown in inches
Voltage for AD558
0.005 (0.13) MIN 0.080 (2.03) MAX 16 9 0.310 (7.87) PIN 1 0.220 (5.59) 1 8 0.320 (8.13) 0.290 (7.37) 0.200 (5.08) 0.840 (21.34) MAX 0.060 (1.52) MAX 0.015 (0.38) 0.150 (3.81) 0.200 (5.08) MIN 0.125 (3.18) 0.015 (0.38) 0.100 0.070 (1.78) SEATING (2.54) PLANE 0.008 (0.20) 0.023 (0.58) 0.030 (0.76) BSC 0.014 (0.36) CONTROLLING DIMENSIONS ARE IN INCHES; MILLIMETER DIMENSIONS (IN PARENTHESES) ARE ROUNDED-OFF INCH EQUIVALENTS FOR REFERENCE ONLY AND ARE NOT APPROPRIATE FOR USE IN DESIGN. 16-Lead Side-Brazed Ceramic Dual In-Line Package [SBDIP] (D-16)
Figure 16. AD558 Settling Characteristics Detail
Dimensions shown in inches and (millimeters)
0 V to 2.56 V Output Range Full-Scale Step
0.180 (4.57) 0.048 (1.22 ) 0.165 (4.19) 0.042 (1.07) 0.056 (1.42) 0.020 (0.50) 0.042 (1.07) 0.20 (0.51) MIN R 3 19 0.021 (0.53) 0.048 (1.22) 4 18 PIN 1 0.050 0.013 (0.33) 0.042 (1.07) IDENTIFIER 0.330 (8.38) BOTTOM (1.27) VIEW TOP VIEW BSC 0.032 (0.81) 0.290 (7.37) (PINS UP) (PINS DOWN) 0.026 (0.66) 8 14 9 13 0.020 0.045 (1.14) (0.51) 0.356 (9.04) R 0.025 (0.64) R 0.350 (8.89) SQ 0.120 (3.04) 0.395 (10.03) 0.090 (2.29) 0.385 (9.78) SQ COMPLIANT TO JEDEC STANDARDS MO-047-AA CONTROLLING DIMENSIONS ARE IN INCHES; MILLIMETER DIMENSIONS (IN PARENTHESES) ARE ROUNDED-OFF INCH EQUIVALENTS FOR REFERENCE ONLY AND ARE NOT APPROPRIATE FOR USE IN DESIGN.
Figure 17. AD558 Settling Characteristic Detail
20-Lead Plastic Leaded Chip Carrier [PLCC] (P-20)
0 V to 10 V Output Range Full-Scale Step
. .A
0.200 (5.08)
.S
0.075 (1.91) REF 0.100 (2.54) REF
U
0.100 (2.54) REF 0.064 (1.63)
IN
0.095 (2.41) 0.015 (0.38) 0.075 (1.90) MIN
TED
19 3 18 20 4
IN
0.358 1 0.028 (0.71) 0.358 (9.09)
PR
0.011 (0.28) 0.342 (8.69) (9.09) BOTTOM 0.022 (0.56) MAX 0.007 (0.18) VIEW SQ SQ 0.050 (1.27) R TYP 14 8 BSC 0.075 (1.91) 13 9 REF 45° TYP 0.088 (2.24) 0.055 (1.40) 0.150 (3.81) 0.054 (1.37) 0.045 (1.14) BSC CONTROLLING DIMENSIONS ARE IN INCHES; MILLIMETER DIMENSIONS (IN PARENTHESES) ARE ROUNDED-OFF INCH EQUIVALENTS FOR REFERENCE ONLY AND ARE NOT APPROPRIATE FOR USE IN DESIGN. 022106-A 20-Terminal Ceramic Leadless Chip Carrier [LCC]
Figure 18. AD558 Logic Timing
(E-20-1) Dimensions shown in inches and (millimeters)
–8– REV. B
