Datasheet ADL5566 (Analog Devices) - 10
Description | 4.5 GHz Ultrahigh Dynamic Range, Dual Differential Amplifier |
Pages / Page | 25 / 10 — Data Sheet. ADL5566. 3.00. 3.3V SUPPLY. 2.75. 5V SUPPLY. ) 2.50. /√Hz. … |
Revision | A |
File Format / Size | PDF / 838 Kb |
Data Sheet. ADL5566. 3.00. 3.3V SUPPLY. 2.75. 5V SUPPLY. ) 2.50. /√Hz. OIP3, 5V, 25°C. OIP3, 3.3V, 25°C. V 2.25. n Y ( 2.00. NS 1.75. m B. DE 1.50
Data Sheet ADL5566 3.00 60 3.3V SUPPLY 2.75 5V SUPPLY ) 2.50 50 /√Hz OIP3, 5V, 25°C OIP3, 3.3V, 25°C V 2.25 n Y ( 2.00 IT 40 ) NS 1.75 m B DE 1.50 d 30 3 ( RAL 1.25 T OIP C E 1.00 P 20 S E 0.75 IS 0.50 NO 10 0.25 0 0 10M 100M 1G
1 008
–6 –5 –4 –3 –2 –1 0 1 2 3 4 5 6 7 8 9 10
1 -0 16- 6
FREQUENCY (Hz) P
91 109
OUT/TONE (dBm)
10 Figure 9. Noise Spectral Density vs. Frequency at VPOS = 3.3 V and VPOS = 5 V Figure 12. Output Third-Order Intercept (OIP3) vs. Output Power (POUT) per Tone, Frequency 200 MHz, VPOS = 3.3 V and VPOS = 5 V
60 0 OIP3, 3.3V, 25°C, 2V p-p IMD3, 3.3V, +25°C, 2V p-p IMD3, 3.3V, +25°C, 1V p-p OIP3, 5V, 25°C, 2V p-p IMD3, 5V, +25°C, 2V p-p IMD3, 5V, +25°C, 1V p-p OIP3, 3.3V, 25°C, 1V p-p IMD3, 3.3V, +85°C, 2V p-p IMD3, 3.3V, +85°C, 1V p-p 50 OIP3, 5V, 25°C, 1V p-p –20 IMD3,5V, +85°C, 2V p-p IMD3, 5V, +85°C, 1V p-p IMD3, 3.3V, –40°C, 2V p-p IMD3, 3.3V, –40°C, 1V p-p IMD3, 5V, –40°C, 2V p-p IMD3, 5V, –40°C, 1V p-p IMD3, 3.3V, +105°C, 2V p-p IMD3, 3.3V, +105°C, 1V p-p 40 –40 IMD3, 5V, +105°C, 2V p-p IMD3, 5V, +105°C, 1V p-p ) m Bm) d 30 –60 3 (dB P D3 ( OI IM 20 –80 10 –100 0
9
–120 0 100 200 300 400 500 600 700 800 900 1000 0 100 200 300 400 500 600 700 800 900 1000
12 -00 0 6-
FREQUENCY (MHz)
916
FREQUENCY (MHz)
091 10 1 Figure 10. Output Third-Order Intercept (OIP3) at Output Level at 2 V p-p Figure 13. IMD3 vs. Frequency, Over Temperature, Output Level at Composite, RL = 200 Ω, VPOS = 3.3 V and VPOS = 5 V 2 V p-p Composite, RL = 200 Ω, VPOS = 3.3 V and VPOS = 5 V
60 –20 –30 50 –40 –50 40 ) m –60 5V B Bc) SUPPLY d d 30 3 ( –70 3.3V P D3 ( SUPPLY OI IM –80 20 OIP3, 3.3V, +25°C, 2V p-p OIP3, 3.3V, +25°C, 1V p-p OIP3, 5V, +25°C, 2V p-p OIP3, 5V, +25°C, 1V p-p –90 OIP3, 3.3V, +85°C, 2V p-p OIP3, 3.3V, +85°C, 1V p-p OIP3, 5V, +85°C, 2V p-p OIP3, 5V, +85°C, 1V p-p –100 10 OIP3, 3.3V, –40°C, 2V p-p OIP3, 3.3V, –40°C, 1V p-p OIP3, 5V, –40°C, 2V p-p OIP3, 5V, –40°C, 1V p-p OIP3, 3.3V, +105°C, 2V p-p OIP3, 3.3V, +105°C, 1V p-p –110 OIP3, 5V, +105°C, 2V p-p OIP3, 5V, +105°C, 1V p-p 0 –120 0 100 200 300 400 500 600 700 800 900 1000
7 010
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
01 16- 6-
FREQUENCY (MHz)
109
VCOM (V)
091 1 Figure 11. Output Third-Order Intercept (OIP3) vs. Frequency, Figure 14. IMD3 vs. VCOM, Output Level at 2 V p-p Composite, RL = 200 Ω, Overtemperature, Output Level at 2 V p-p Composite, RL = 200 Ω, VPOS = 3.3 V and VPOS = 5 V, Frequency = 100 MHz VPOS = 3.3 V and VPOS = 5 V Rev. A | Page 9 of 24 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description Applications Information Basic Connections Input and Output Interfacing Single-Ended Input to Differential Output Gain Adjustment and Interfacing ADC Interfacing DC-Coupled Receiver Application Layout Considerations Soldering Information and Recommended Land Pattern Evaluation Board Outline Dimensions Ordering Guide
