Datasheet ADL5565 (Analog Devices) - 9
Description | 6 GHz Ultrahigh Dynamic Range Differential Amplifier |
Pages / Page | 29 / 9 — ADL5565. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max … |
Revision | G |
File Format / Size | PDF / 909 Kb |
ADL5565. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max Unit
ADL5565 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
200 MHz Second/Third Harmonic Distortion (HD2/HD3) AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −82/−87 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −72/−86 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −71/−86 dBc Output IP3/Third-Order Intermodulation AV = 6 dB, RL = 200 Ω, VOUT = +46/−96 dBm/dBc Distortion (OIP3/IMD3) 2 V p-p composite AV = 12 dB, RL = 200 Ω, VOUT = +46/−96 dBm/dBc 2 V p-p composite AV = 15.5 dB, RL = 200 Ω, VOUT = +46/−96 dBm/dBc 2 V p-p composite Second-Order Intermodulation Distortion (IMD2) AV = 6 dB, RL = 200 Ω, VOUT = −85 dBc 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = −74 dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = −70 dBc 2 V p-p composite (2 MHz spacing) Noise Spectral Density, RTI (NSD) AV = 6 dB 2.43 nV/√Hz AV = 12 dB 1.63 nV/√Hz AV = 15.5 dB 1.51 nV/√Hz Noise Figure (NF) AV = 6 dB 10.88 dB AV = 12 dB 9.2 dB AV = 15.5 dB 8.54 dB 500 MHz Second/Third Harmonic Distortion (HD2/HD3) AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −69/−66 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −56/−65 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −58/−66 dBc Output IP3/Third-Order Intermodulation AV = 6 dB, RL = 200 Ω, VOUT = +35/−74 dBm/dBc Distortion (OIP3/IMD3) 2 V p-p composite AV = 12 dB, RL = 200 Ω, VOUT = +35/−74 dBm/dBc 2 V p-p composite AV = 15.5 dB, RL = 200 Ω, VOUT = +37/−78 dBm/dBc 2 V p-p composite Second-Order Intermodulation Distortion (IMD2) AV = 6 dB, RL = 200 Ω, VOUT = −73 dBc 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = −75 dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = −72 dBc 2 V p-p composite (2 MHz spacing) Noise Spectral Density, RTI (NSD) AV = 6 dB 2.64 nV/√Hz AV = 12 dB 1.6 nV/√Hz AV = 15.5 dB 1.48 nV/√Hz Noise Figure (NF) AV = 6 dB 11.56 dB AV = 12 dB 9.06 dB AV = 15.5 dB 8.17 dB Rev. E | Page 8 of 28 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications 3.3 V Specifications 5 V Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description Basic Structure Applications information Basic Connections Input and Output Interfacing Single-Ended Input to Differential Output Gain Adjustment and Interfacing ADC Interfacing Layout Considerations Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
