Datasheet ADA4930-1 (Analog Devices) - 9
DescriptionUltralow Noise Drivers for Low Voltage ADCs
Pages / Page17 / 9 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/13615
File Format / SizePDF / 220 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/13615
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit V type S = 5 V, TA unless otherwise specified Min Max Dynamic performance. -3 dB small signal SSBW VO,dm = 0.1 VP-P +25°C 01 1350 typical MHz bandwidth -3 dB large signal LSBW VO,dm = 2 VP-P +25°C 01 937 typical MHz bandwidth Bandwidth for 0.1 dB VO,dm = 0.1 VP-P +25°C 01 369 typical MHz flatness Slew rate SR VO,dm = 2 V step, 25% to 75% +25°C 01 3400 typical V/µs Settling time to 0.1% tS VO,dm = 2 V step, RL = 200 Ω +25°C 01 6 typical ns Overdrive recovery G = 3, VIN,dm = 0.7 VP-P pulse +25°C 01 1.5 typical ns time Noise / harmonic performance. Second harmonic HD2 VO,dm = 2 VP-P, fC = 10 MHz -55°C to +105°C 01 -104 typical dBc distortion VO,dm = 2 VP-P, fC = 30 MHz -91 typical VO,dm = 2 VP-P, fC = 70 MHz -79 typical VO,dm = 2 VP-P, fC = 100 MHz -73 typical Third harmonic HD3 VO,dm = 2 VP-P, fC = 10 MHz -55°C to +105°C 01 -101 typical dBc distortion VO,dm = 2 VP-P, fC = 30 MHz -93 typical VO,dm = 2 VP-P, fC = 70 MHz -82 typical VO,dm = 2 VP-P, fC = 100 MHz -75 typical Third order V +25°C 01 94 typical dBc O,dm = 1 VP-P / tone, intermodulation f distortion (IMD) C = 70.05 MHz ±0.05 MHz V 90 typical O,dm = 1 VP-P / tone, fC = 140.05 MHz ±0.05 MHz See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/13615
REV PAGE 9 Document Outline DESCRIPTION REV REV PMIC N/A DLA LAND AND MARITIME TITLE SIZE A V62/13615 REV
