Datasheet AD8139 (Analog Devices) - 2
DescriptionLow Noise, Rail-to-Rail, Differential ADC Driver
Pages / Page27 / 2 — AD8139* PRODUCT PAGE QUICK LINKS Last Content Update: 09/22/2017. …
RevisionC
File Format / SizePDF / 597 Kb
AD8139* PRODUCT PAGE QUICK LINKS Last Content Update: 09/22/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8139* PRODUCT PAGE QUICK LINKS Last Content Update: 09/22/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Single Differential • MT-075: Differential Drivers for High Speed ADCs Amplifiers Overview • MT-076: Differential Driver Analysis
DOCUMENTATION
• MT-218: Multiple Feedback Band-Pass Design Example
Application Notes
• AN-0992: Active Filter Evaluation Board for Differential
DESIGN RESOURCES
Amplifiers • AD8139 Material Declaration • AN-1026: High Speed Differential ADC Driver Design • PCN-PDN Information Considerations • Quality And Reliability • AN-1363: Meeting Biasing Requirements of Externally Biased RF/Microwave Amplifiers with Active Bias • Symbols and Footprints Controllers • AN-584: Using the AD813X Differential Amplifier
DISCUSSIONS
• AN-649: Using the Analog Devices Active Filter Design View all AD8139 EngineerZone Discussions. Tool
Data Sheet SAMPLE AND BUY
• AD8139: Low Noise, Rail-to-Rail, Differential ADC Driver Visit the product page to see pricing options. Data Sheet
User Guides TECHNICAL SUPPORT
• UG-474: Evaluation Board for Differential Amplifiers Submit a technical question or find your regional support Offered in 8-Lead SOIC Packages number.
TOOLS AND SIMULATIONS DOCUMENT FEEDBACK
• ADI DiffAmpCalc™ Submit feedback for this data sheet. • AD8139 SPICE Macro Model
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VS = ±5 V, VOCM = 0 V VS = 5 V, VOCM = 2.5 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION TYPICAL CONNECTION AND DEFINITION OF TERMS Output Balance APPLICATIONS INFORMATION ESTIMATING NOISE, GAIN, AND BANDWIDTH WITH MATCHED FEEDBACK NETWORKS Estimating Output Noise Voltage Voltage Gain Feedback Factor Notation Input Common-Mode Voltage Calculating Input Impedance Input Common-Mode Swing Considerations Bandwidth vs. Closed-Loop Gain Estimating DC Errors Other Impact of Mismatches in the Feedback Networks Driving a Capacitive Load Layout Considerations Terminating a Single-Ended Input Exposed Paddle (EP) OUTLINE DIMENSIONS ORDERING GUIDE
