Datasheet AD8139 (Analog Devices) - 10
DescriptionLow Noise, Rail-to-Rail, Differential ADC Driver
Pages / Page27 / 10 — Data Sheet. AD8139. TYPICAL PERFORMANCE CHARACTERISTICS. G = 1. G = 2. N …
RevisionC
File Format / SizePDF / 597 Kb
Data Sheet. AD8139. TYPICAL PERFORMANCE CHARACTERISTICS. G = 1. G = 2. N (. G = 5. G = 10. D CL. –10. –11. RG = 200Ω. –12. G = 200Ω
Data Sheet AD8139 TYPICAL PERFORMANCE CHARACTERISTICS G = 1 G = 2 N ( G = 5 G = 10 D CL –10 –11 RG = 200Ω –12 G = 200Ω
link to page 19
Unless otherwise noted, differential gain = +1, RG = RF = 200 Ω, RL, dm = 1 kΩ, VS = ±5 V, TA = 25°C, VOCM = 0 V. Refer to the basic test circuit in Figure 57 for the definition of terms.
2 2 G = 1 1 1 G = 1 B) 0 B) 0 d G = 2 d –1 N ( –1 N ( G = 5 G = 2 AI –2 AI –2 G G P –3 P –3 O O O –4 O –4 -L -L D –5 D –5 E E S G = 5 –6 S O –6 O G = 10 –7 –7 D CL G = 10 –8 D CL E –8 E IZ –9 IZ –9 AL AL –10 –10 RM RM –11 –11 NO R NO RG = 200Ω –12 G = 200Ω V –12 V O, dm = 0.1V p-p O, dm = 2.0V p-p –13 –13 1 10 100 1000
04 07 -0
1 10 100 1000
-0 79 79
FREQUENCY (MHz)
46
FREQUENCY (MHz)
46 0 0 Figure 7. Small Signal Frequency Response for Various Gains Figure 10. Large Signal Frequency Response for Various Gains
5 3 4 2 V 3 S = +5V 1 2 0 ) 1 ) B –1 B d d ( 0 ( –2 IN V IN V –1 S = ±5V –3 S = ±5V GA –2 GA –4 VS = +5V OOP –3 OOP –5 -L –4 -L D –6 D E E –5 –7 OS OS L –6 L C –8 C –7 –9 –8 –10 –9 V –11 O, dm = 0.1V p-p VO, dm = 2.0V p-p –10 –12 10 100 1000
05 08 -0
10 100 1000
-0 79 79
FREQUENCY (MHz)
46
FREQUENCY (MHz)
46 0 0 Figure 8. Small Signal Frequency Response for Various Power Supplies Figure 11. Large Signal Frequency Response for Various Power Supplies
3 3 +125°C +125°C +85°C 2 2 +85°C 1 1 0 0 ) –1 ) B –1 B d d ( –2 ( –2 IN IN –3 –3 GA –4 GA –4 OOP –5 OOP –5 -L –40°C –6 -L D –6 D E E –7 –7 OS OS L –8 L C –8 C –9 –9 –40°C +25°C –10 –10 –11 VO, dm = 0.1V p-p –11 V +25°C O, dm = 2.0V p-p –12 –12 10 100 1000
06 09 -0
10 100 1000
-0 79 79
FREQUENCY (MHz)
46
FREQUENCY (MHz)
46 0 0 Figure 9. Small Signal Frequency Response at Various Temperatures Figure 12. Large Signal Frequency Response at Various Temperatures Rev. C | Page 9 of 26 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VS = ±5 V, VOCM = 0 V VS = 5 V, VOCM = 2.5 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION TYPICAL CONNECTION AND DEFINITION OF TERMS Output Balance APPLICATIONS INFORMATION ESTIMATING NOISE, GAIN, AND BANDWIDTH WITH MATCHED FEEDBACK NETWORKS Estimating Output Noise Voltage Voltage Gain Feedback Factor Notation Input Common-Mode Voltage Calculating Input Impedance Input Common-Mode Swing Considerations Bandwidth vs. Closed-Loop Gain Estimating DC Errors Other Impact of Mismatches in the Feedback Networks Driving a Capacitive Load Layout Considerations Terminating a Single-Ended Input Exposed Paddle (EP) OUTLINE DIMENSIONS ORDERING GUIDE
