Datasheet AD8139 (Analog Devices) - 7
DescriptionLow Noise, Rail-to-Rail, Differential ADC Driver
Pages / Page27 / 7 — AD8139. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
RevisionC
File Format / SizePDF / 597 Kb
AD8139. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD8139 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
POWER SUPPLY Operating Range +4.5 ±6 V Quiescent Current 21.5 22.5 mA +PSRR Change in +VS = ±1 V 86 97 dB −PSRR Change in −VS = ±1 V 92 105 dB OPERATING TEMPERATURE RANGE −40 +125 °C Rev. C | Page 6 of 26 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VS = ±5 V, VOCM = 0 V VS = 5 V, VOCM = 2.5 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION TYPICAL CONNECTION AND DEFINITION OF TERMS Output Balance APPLICATIONS INFORMATION ESTIMATING NOISE, GAIN, AND BANDWIDTH WITH MATCHED FEEDBACK NETWORKS Estimating Output Noise Voltage Voltage Gain Feedback Factor Notation Input Common-Mode Voltage Calculating Input Impedance Input Common-Mode Swing Considerations Bandwidth vs. Closed-Loop Gain Estimating DC Errors Other Impact of Mismatches in the Feedback Networks Driving a Capacitive Load Layout Considerations Terminating a Single-Ended Input Exposed Paddle (EP) OUTLINE DIMENSIONS ORDERING GUIDE
