Datasheet AD8132 (Analog Devices) - 2
DescriptionLow Cost, High Speed Differential Amplifier
Pages / Page33 / 2 — AD8132* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionI
File Format / SizePDF / 518 Kb
AD8132* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD8132* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • ADI DiffAmpCalc™ • AD8132 SPICE Macro-Model
EVALUATION KITS
• Universal Evaluation Board for Single Differential
REFERENCE MATERIALS
Amplifiers
Product Selection Guide
• Amplifiers for Video Distribution
DOCUMENTATION
• High Speed Amplifiers Selection Table
Application Notes Tutorials
• AN-0990: Terminating a Differential Amplifier in Single- • MT-075: Differential Drivers for High Speed ADCs Ended Input Applications Overview • AN-0992: Active Filter Evaluation Board for Differential • MT-076: Differential Driver Analysis Amplifiers • MT-218: Multiple Feedback Band-Pass Design Example • AN-1026: High Speed Differential ADC Driver Design Considerations
DESIGN RESOURCES
• AN-1363: Meeting Biasing Requirements of Externally Biased RF/Microwave Amplifiers with Active Bias • AD8132 Material Declaration Controllers • PCN-PDN Information • AN-282: Fundamentals of Sampled Data Systems • Quality And Reliability • AN-584: Using the AD813X Differential Amplifier • Symbols and Footprints • AN-589: Ways to Optimize the Performance of a Difference Amplifier
DISCUSSIONS
• AN-649: Using the Analog Devices Active Filter Design View all AD8132 EngineerZone Discussions. Tool
Data Sheet SAMPLE AND BUY
• AD8132: Low-Cost, High Speed Differential Amplifier Data Visit the product page to see pricing options. Sheet
User Guides TECHNICAL SUPPORT
• UG-474: Evaluation Board for Differential Amplifiers Offered in 8-Lead SOIC Packages Submit a technical question or find your regional support number. • UG-888: Evaluation Board for Differential Amplifiers Offered in 8-Lead MSOP Packages
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OPERATIONAL DESCRIPTION DEFINITION OF TERMS Differential Voltage Common-Mode Voltage BASIC CIRCUIT OPERATION THEORY OF OPERATION GENERAL USAGE OF THE AD8132 DIFFERENTIAL AMPLIFIER WITHOUT RESISTORS (HIGH INPUT IMPEDANCE INVERTING AMPLIFIER) OTHER β2 = 1 CIRCUITS VARYING β2 β1 = 0 ESTIMATING THE OUTPUT NOISE VOLTAGE CALCULATING INPUT IMPEDANCE OF THE APPLICATION CIRCUIT INPUT COMMON-MODE VOLTAGE RANGE IN SINGLE-SUPPLY APPLICATIONS SETTING THE OUTPUT COMMON-MODE VOLTAGE DRIVING A CAPACITIVE LOAD OPEN-LOOP GAIN AND PHASE LAYOUT, GROUNDING, AND BYPASSING CIRCUITS APPLICATIONS INFORMATION ANALOG-TO-DIGITAL DRIVER BALANCED CABLE DRIVER TRANSMIT EQUALIZER LOW-PASS DIFFERENTIAL FILTER HIGH COMMON-MODE OUTPUT IMPEDANCE AMPLIFIER FULL-WAVE RECTIFIER AUTOMOTIVE PRODUCTS OUTLINE DIMENSIONS ORDERING GUIDE
