Datasheet AD8138 (Analog Devices) - 8
DescriptionLow Distortion Differential ADC Driver
Pages / Page12 / 8 — VOCM TO ±OUT SPECIFICATIONS. Dynamic performance. Noise. DC performance. …
File Format / SizePDF / 227 Kb
VOCM TO ±OUT SPECIFICATIONS. Dynamic performance. Noise. DC performance. Power supply. DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236
VOCM TO ±OUT SPECIFICATIONS Dynamic performance Noise DC performance Power supply DLA LAND AND MARITIME COLUMBUS, OHIO 16236
TABLE I. Electrical performance characteristics - Continued. 1/ Test Symbol Test conditions Limits Unit Min Typ Max
5/
Dynamic performance
-3dB bandwidth 220 MHz Slew rate 250 V/µs
Noise
Input voltage noise (RTI) f = 0.1 MHz to 100 MHz 17 nv/√Hz
DC performance
Input voltage range 1.0 to 3.8 V Input resistance 100 kΩ Input offset voltage VOS, cm = VOUT, cm; VDIN+ = VDIN- = VOCM = 0 V -5 ±1 +5 mV TMIN to TMAX 3/ -9.7 +9.7 Input bias current 0.5 µA VOCM CMRR ΔVOUT, dm/ΔVOCM; ΔVOCM = 2.5 ±1 V, -70 dB Gain ΔVOUT, cm/ΔVOCM; ΔVOCM = 2.5 ±1 V; 0.9968 1 1.0032 V/V TMIN to TMAX 3/
Power supply
Operating range 2.7 11 V Quiescent current 15 20 21 mA TMIN to TMAX 3/ 10.6 mA Power supply rejection ratio ΔVOUT, dm/ΔVS, ΔVS = ±1 V; -90 -70 dB TMIN to TMAX 3/ -57 Operating temperature range -55 +105 °C 1/ Testing and other quality control techniques are used to the extent deemed necessary to assure product performance over the specified temperature range. Product may not necessarily be tested across the full temperature range and all parameters may not necessarily be tested. In the absence of specific parametric testing, product performance is assured by characterization and/or design. 2/ At 25°C, VS = ±5 V, VOCM = 0 V, G = +1, RL, dm = 500 Ω, unless otherwise noted. All specifications refer to single ended input and differential outputs, unless otherwise noted. 3/ Specified to ±6 sigma over the -40°C to +105°C operating temperature range. 4/ Output swing capabilities vary over operating temperature. See FIGURE 5 for more information. 5/ At 25°C, VS = 5 V, VOCM = 2.5 V, G = +1, RL, dm = 500 Ω, unless otherwise noted. All specifications refer to single ended input and differential outputs, unless otherwise noted.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12629
REV PAGE 8 Document Outline DESCRIPTION REV REV PMIC N/A TITLE SIZE A V62/12629 REV
