Datasheet AD8138 (Analog Devices) - 10
DescriptionLow Distortion Differential ADC Driver
Pages / Page12 / 10 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12629
File Format / SizePDF / 227 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12629
Case outline X Terminal Terminal Terminal Terminal number symbol number symbol 1 -IN 8 +IN 2 VOCM 7 NC 3 V+ 6 V- 4 +OUT 5 -OUT FIGURE 2. Terminal connections. Terminal Description Number Mnemonic 1 -IN Negative input summing node. 2 VOCM Voltage applied to this pin sets the common mode output voltage with a ratio of 1:1. For example, 1 Vdc on VOCM sets the dc bias level on +OUT and –OUT to 1 V. 3 V+ Positive supply voltage. 4 +OUT Positive output. Note that the voltage at -DIN is inverted at +OUT. 5 -OUT Negative output. Note that the voltage at +DIN is inverted at -OUT. 6 V- Negative supply voltage. 7 NC No connect. 8 +IN Positive input summing node. FIGURE 3. Terminal function. 1.75 1.50 ) (W 1.25 1.00 0.75 0.50 MAXIMUM POWER DISSIPATION 0.25 0 -55 -45 -35 -25 -15 -5 5 15 25 35 45 55 65 75 85 95 105 AMBIENT TEMPERATURE(°C) FIGURE 4. Maximum power dissipation vs ambient temperature.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12629
REV PAGE 10 Document Outline DESCRIPTION REV REV PMIC N/A TITLE SIZE A V62/12629 REV
